help with b20 head p8r
Old Mar 3, 2008 | 09:24 PM
superfast666's Avatar
Default help with b20 head p8r
does any one know how much you would have to mill a b20 p8r head to fit a b18b1 block
Old Mar 4, 2008 | 07:39 AM
chad's Avatar
Moderator
Default Re: help with b20 head p8r (superfast666)
ZERO
it will bolt right up
Old Mar 4, 2008 | 06:45 PM
Default Re: help with b20 head p8r (chad)
can any one confirm this
Old Mar 5, 2008 | 07:53 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 &raquo;</TD></TR><TR><TD CLASS="quote">can any one confirm this</TD></TR></TABLE>
look at my post count....i'm a mod in this forum, i'm pretty sure i know what i'm talking about.
i have 2 b20's
1 b20 bahhhhhhhhhhhhtec
1 b18c5
1 b18c1
1 b18c
1 b18b
2 b16a's
at least a dozen b series heads....i have a pr8 just sitting there....all in my personal garage
Old Mar 5, 2008 | 07:54 AM
chad's Avatar
Moderator
if you are talking about the 84 mm bore on the head well.....if you mill it that much to take that away then you are going to have to notch your pistons so the cam does not cause the valve to hit the piston!!
Old Mar 5, 2008 | 05:15 PM
thanks man
Old Mar 9, 2008 | 10:23 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
wouldn't milling it that much warp the head? how much milling are we talking about here? more than the serivice limit? wouldn't be better to weld and reshape the chambers, or just run an 84mm block?
clevelee
Dec 3, 2008 11:53 PM
nitewolf
Mar 28, 2008 10:34 PM
Dammit_Dan_954
Apr 15, 2004 07:44 PM
AudioXtremes
Mar 31, 2003 02:47 PM
