Bent suspension?
Old Mar 3, 2008 | 07:16 PM
prelude_93vtec's Avatar
Default Bent suspension?
This is really bothering me now.
My uncle hit a curb when he had the car and the wheel is set back and is tilted. Can a simple alignment fix this or would I need to replace something?
BTW the top is the wheel against the fender and the bottom is angle of steering wheel.
Car pulls to the left and when taking a right turn, feels like the grip of the road sucks compared to taking a left turn. And this is on the Front Driver side
Old Mar 3, 2008 | 08:54 PM
Default Re: Bent suspension? (prelude_93vtec)
Overnight bump. Takin the car to school tomorrow and wanna know what to check
Old Mar 3, 2008 | 09:26 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec &raquo;</TD></TR><TR><TD CLASS="quote">This is really bothering me now.
An alignment most likely wil not fix it. He bent something....or multiple things, for example the radius rods, crossmember, LCA, UCA, etc.
You might be able to look under there and see what is bent, but it sounds like you need to take it to a shop.
Old Mar 4, 2008 | 02:49 PM
bb4 jdm lude's Avatar
Default Re: Bent suspension? (Hawkze_2.3)
i had kinda the same problem most likely a bent LCA
Old Mar 4, 2008 | 05:57 PM
Default Re: Bent suspension? (bb4 jdm lude)
http://cgi.ebay.com/ebaymotors...59583
what do you guys think about that?
Old Mar 4, 2008 | 06:10 PM
drbenne's Avatar
Those items don't include a lower control arm, If your problem is a bent LCA you're still gonna have the same problem after you replace those parts
Old Mar 4, 2008 | 07:12 PM
Default Re: Bent suspension? (drbenne)
Lol yea I'm takin it to a shop and checking whats bent. If its just the LCA, I'd be in luck cause I can get one for around 40 bucks
Old Mar 4, 2008 | 08:55 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...59583
what do you guys think about that?</TD></TR></TABLE>
Yeah, it's probably not going to be any of those....tie rod ends flex with the wheel in any direction so they most likely won't be bent.
If the wheel is pushed back that means the caster is off, which is held in place by the radius rods and front crossmember. So it's probably those plus the LCA.....but the shop will tell you for sure
Old Mar 5, 2008 | 03:43 AM
tacticalcustoms's Avatar
when I hit a curb, I had to replace LCA and radius rod. + alignment.
Old Mar 5, 2008 | 05:01 AM
Default Re: Bent suspension? (tacticalcustoms)
yeah man i just got this takin care of and the shop i took mine to said i had a bent LCA and 2 bolts and nuts missing on the suspension.... i fixed the two bolts and nuts and the car handles almost like a new car even with the bent LCA. So i havent replaced it yet. where can u get a LCA for 40 bucks at besides a Junkyard
Old Mar 5, 2008 | 09:31 AM
drbenne's Avatar
better hurry..
http://cgi.ebay.com/ebaymotors...ZWD1V
Shiznit028
21
Dec 17, 2008 03:39 AM
crxzcracer
Mar 26, 2005 06:08 PM
GR_DC2
Suspension & Brakes
Jan 17, 2005 07:04 PM
tomy_r
Oct 13, 2004 08:44 PM
ncitrdude
May 15, 2002 12:37 PM
