2000 civic si
i have so questions that i need anwered please.
1. if you use a h2b kit with the h22 motor in a civic si do you use the transmission that can with the car( witch is a stock b16)?
2. and what is the coast of the h2b kit??
3. dose the h2b kit come with everything that you need to hook up the b16 trans?
3. do u need to change any of the shitfing cables or anything else?
4. do anyone knows how much faster a civic si with the h22 swap be??
help please!!!!
help please!!!!
h22 motor is using cable tranny. which means u can not reuse b16 or any hydro trany. u will have to cut a hole for the shifter bazel to fit. i would stay with b16a engine.. less hassle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EDM-itR »</TD></TR><TR><TD CLASS="quote">dont h22's come with hydro transmissions, meaning you can pair it up with a hydro b16 tranny</TD></TR></TABLE>
no. h22 is cable. do a search and there are tons of people posting about h22a swap into eg or ek in this forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick824 »</TD></TR><TR><TD CLASS="quote">
help please!!!!</TD></TR></TABLE>
Alot faster, getting out of an EM1 and driving an H22 swapped Ej1 would make your jaw drop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">
no. h22 is cable. do a search and there are tons of people posting about h22a swap into eg or ek in this forum.</TD></TR></TABLE>
nope, its hydro
the but instead of using shift linkages it uses cables
the clutch is hydro
nope, its hydro
the clutch is hydro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick824 »</TD></TR><TR><TD CLASS="quote">i do not know what the Ej1 is?? i have never heard of it. </TD></TR></TABLE>
92-25 Civic Ex Coupe
By the looks of it youve got some reading to do
YOUR not doing this swap yourself right?
you need to check out the hybrid section. there is a lot of write ups on h2b. I'm also doing h2b in my 00si. I would seggust trying to source and obd2 motor. so that it's pretty much plug and play. get ready to lose a/c and p/s thow....
Silvafox
Apr 7, 2009 10:22 AM
drocto3000
May 27, 2008 09:13 PM
Civic_kid_666
Jan 17, 2008 12:29 PM
i'm slow...trust me
36
Jul 18, 2005 05:29 PM
