so my gauges and my corners stoped working after amber bulbs in gauge install
so i put the amber bulbs to replace the stock gauge lights and it lit up fine for 10 min. Then they went out...i noticed that my carners stoped working also...they only work when i put my blinkers or hazards, but not when the lights are on.
My srs light also went on. Maybe you guys know whats up?
Thanks
Thanks
Sounds to me like your cluster came unplugged. If you have the key on when you remove the cluster, you'll get an srs light. If it falls unplugged, it will throw an srs light. Pull the cluster and make sure the plugs are "locked" on.
401RIguy
17
Mar 8, 2009 07:49 PM
Andrew Marquis
Mar 1, 2006 10:43 AM
