Classic Hondas All Pre-1988 Hondas.
83 Civic: What should be replaced? Been sitting for awhile.
Old Mar 3, 2008 | 03:17 PM
RuskeR's Avatar
Default 83 Civic: What should be replaced? Been sitting for awhile.
Here she is...
She sat in my parents garage for 2 years, and then was moved outside for another 2 years. Only has 150k original miles and I've waited long enough to start driving her. Gas is getting up there now so I'll park the STi for the daily driving and drive this if I get her running again.
As you can guess the fuel and oil as just as old. Oil isn't a problem but I know the fuel will be an issue.
Will just draining the tank and refilling it be enough or will I need to clean the tank? Hopefully the old fuel hasn't damaged anything in the fuel lines. She ran great when she was parked and forgotten.
I figured with new oil, belts, lines and fuel she should be good to go.
Modified by RuskeR at 4:38 PM 3/3/2008
Old Mar 4, 2008 | 07:48 AM
cbstd's Avatar
Default Re: 83 Civic: What should be replaced? Been sitting for awhile. (RuskeR)
It sounds like you know what to check and replace. I would also throw in a new timing belt and water pump, "just to be safe." I do not know how much fun it will be to drive after parking your STi.
That old Civic looks clean, I hope you preserve it as a survivor.
Scott
Old Mar 4, 2008 | 11:53 AM
RuskeR's Avatar
The 240 is in between things right now so that won't be driveable until at least spring, so this is my only other option.
Best way to remove the old fuel is to just use a cut garden hose and start sucking? :D
Old Mar 4, 2008 | 12:12 PM
cbstd's Avatar
Default Re: (RuskeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuskeR &raquo;</TD></TR><TR><TD CLASS="quote"> Best way to remove the old fuel is to just use a cut garden hose and start sucking? :D</TD></TR></TABLE>
If there is no drain plug, you can remove the fuel line and let it drain from there.
Old Mar 4, 2008 | 05:43 PM
NW Classic Honda's Avatar
Sweet another Seattle classic Honda guy! Bring it to the HT meet!
Old Mar 5, 2008 | 07:48 AM
slicksapp's Avatar
i have an 82 civic that sat for a while. i had rust in the gas tank and carb. like rust chips in the gas tank. I would suggest draining the old gas, if its orange you gotta problem. you'll probably have to get a new tank. and you might have to rebuild the carb. also change oil, fluids, sparkplugs, timing belt, water pump ect... to drain the gas theres a drain on the actual tank.
Old Mar 5, 2008 | 01:25 PM
RuskeR's Avatar
The 82 will be a few things done before I bring it to a meet.
slickapp.. how long did yours sit for? Any problems starting it?
Old Mar 5, 2008 | 11:30 PM
batac_boy's Avatar
if you need any tune up parts for this car let me know what you need and Ill get you a price for everything
pm me give me your info where i can reach you....i might be able to help you.
Old Mar 6, 2008 | 10:35 AM
turnofftheradio's Avatar
Check you gas as stated, but I also pull the spark plugs, after the oil change, squirt a bit of oil into each cylinder, then turn the engine over with the plugs out until you get the oil pressure light to come off, replace plugs and then try to get it to start. I t just makes sure you have oil where you need it, when you need it.
forevermemorabl
Oct 28, 2013 04:54 PM
Jex
Nov 17, 2012 02:39 AM
backstrap1
Honda S2000
Mar 22, 2010 06:32 PM
mooneybeams
Mar 16, 2007 10:20 AM
Martaigne
Jul 31, 2002 05:08 PM
