bouncy idle... tps gasket?
i just had a new tb and IM installed, so all the sensors were transfered. my idle is bouncy from 1000-1500 so i was looking around for a air leak. i saw the the gasket on the tps sensor was a bit worn. will a bad tps gasket cause a air leak and cause a bouncy idle???
whats the best way to check where a air leak is coming from???
tps is just a coil, a broken gasket wont do anything. Did you adjust the tps to the correct angle? It should be at .45k ohms idle if you read the far left leads with a meter.
95dc2teg
Sep 11, 2007 05:49 PM
