HONDA CIVIC 1.8 VTI FUELLING
Old Mar 3, 2008 | 09:45 AM
mb6vtis's Avatar
Default HONDA CIVIC 1.8 VTI FUELLING
Hello people will adding a Sard or AEM fuel regulator make a difference on the vehicle listed below on standard fuel rail and injectors.. my aim is to increase my torque..
Car Spec
Honda Civic 1.8 VTI-S
Engine: B18C4
Shape: 5 Door Hatcback
Year: 1998
Current Mods:
A/C Removed, Forced induction, Irdium Spark plugs, DECAT,
custom made muffler straight through exit
any helpful replys will be very much appreciated..
Old Mar 3, 2008 | 10:17 PM
inspyral's Avatar
I'm assuming by "forced induction" you're referring to some sort of cold air or ram air intake? If so, then your list of mods isn't too far from stock, so you probably won't benefit much, if at all from an adjustable fuel pressure regulator. I would spend the money elsewhere.
If "forced induction" means a turbo, supercharger, or nitrous, then an adjustable FPR may or may not be necessary for your setup. For instance, some larger fuel injectors run better at lower base fuel pressures, so in that case, you may need an aftermarket FPR to lower your fuel pressure.
Old Mar 4, 2008 | 02:57 PM
mb6vtis's Avatar
Default Re: (inspyral)
ok kool thanx.. sorry yeh its NA
I mean Cold feed intake.. pipe located from under bumper to air filter
Current mods
Iridium Plugs, Decat and muffler custom made no restriction
Cold feed intake, A.C removed weight saving
has anybody on here fitted a skunk2 intake manifold? suppose to be the same design as the type r integra manifold
b18c4 engine has dual intake runners this causes restriction designed for economy
my aim is to increase torque rather than bhp..
any recommendations???
Old Mar 4, 2008 | 03:49 PM
inspyral's Avatar
The Skunk and other aftermarket single-stage intake manifolds for GSR heads that mimic the OEM ITR manifold will usually yield increases in the upper RPM range if tuned properly. The key to extracting that power is all in the tuning, since the stock ECU is optimized for the dual-stage intake. A single-stage, ITR-style intake manifold on a GSR head without proper tuning(either thru a chipped ECU, standalone EMS, or a piggyback controller - tuned on a dyno) will most likely result in a loss of low end power.
dointhemzs
Sep 16, 2008 09:17 PM
dointhemzs
Sep 16, 2008 04:48 PM
zseeanz
Apr 5, 2004 07:48 AM
spun Vtec
Nov 7, 2002 09:27 AM
92t3gra
Aug 9, 2001 05:49 PM
