Camber Kit on EG
I have a '95 Civic coupe with 205/40/17 tires. If I buy one of those $40 camber kits from ebay. The ones with the blocks that push the top of the wheel out. Will the tire rub the fender well or have any clearance issues at all. this is the set I am talkign about for the front and the rear.
Modified by carma42 at 1:40 PM 3/3/2008
That had no logic or theory behind that at all. I would like to know if this or any will affect tire clearance in the wheel well. The Skunk2 may not have any clearance issues but These as far as moving the camber take the top out not the bottom in. Let me know if you have had any experience with these I show instead of short non informative answers. Thanks.
Not sure why anybody is bothering to comment on the wheel choice... that's irrelevant...
The camber kit, if installed correctly will solve your camber problem. However, nobody can say for sure whether it will cause rubbing, etc. That depends on your wheel and tire selection, the stiffness of your suspension setup, your drop, whether you have your fender well linings installed/tucked/removed, etc.
Simply providing the tire size will not answer your question. Still need wheel offset, damper choice, spring choice, drop height (if adjustable), etc etc.
panchlow
Feb 12, 2011 03:22 PM
alacard
Suspension & Brakes
19
Jun 25, 2007 10:39 AM
danyerudono
14
Aug 24, 2004 06:39 AM
Kalokohan
Apr 17, 2003 12:46 PM
