B Series Axles Questions
are all b series axles compatable with each other?... like if i get a si halfshaft, can i run it with some integra axles...
what are axles w/o abs ... and what is.... are type r axles compatable with si halfshafts.. let me know
i know some 1 selling some type r axles for $120 ... are they worth it?
yes .if u get a si halfshaft and in fact,it is the same as 94 and up integra's, u can use axles from 99-00 civic si or 94 and up integra's axles. to use abs or not.it depends on if u have abs brake. if u dont have abs brake. u can use non abs or abs axles.but non abs axles are cheaper. for type r axles. are they used or new? i got a pair of brand new axles from local parts store with life time warranty for about $150. they are 94 and up gsr spec with no abs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xlasianizelx »</TD></TR><TR><TD CLASS="quote">They are used </TD></TR></TABLE>
and i ran part numbers check,and gsr and type r oem axles are the same.prices are the same at acura parts.
