ingalls camber kit (pics)
hello every one ive been researching around for camber kits and i came across this ingalls one that will agjust from 1.5- 3 degrees negitive camber. its not the ***** joint one cause i think there junk and its not the A arm one cause they will hit my innner fender. tell me what ya think if its good bad and any recomendations.
and heres a pick of my camber issue.
Are you sure they upper A arms will hit your fender? Mine are fine, and they allow you to adjust the position of the ball joint. They would be my choice over those, they will also give you more adjustability.
...i just installed my kit on my DA...im running no finger gap up front...i have no clearance issues at all
check my post in this thread
https://honda-tech.com/zerothread?id=2218804
Ingalls worked well with my 89 civic and my bros 91 Crx. Make sure after you install it, get an alignment....never had any camber issues after I installed them...thinking about getting a set for my integra pretty soon...
eTec
19
May 21, 2002 04:51 AM
