Timing question.
I read to get the timing right on your ef when you time it you have to JUMP Some sort of thing so it can go into a certain mode....
B16a 91 ef si....
Were talking ignition timing,.. I did it right, but i read you have to jump some sort of plug to get the timing ACTUALLY right?
ANY input?>
B16a 91 ef si....
ANY input?>
Alright, It is called the service connector. On the 91's it isn't needed but if you wish to check it, It should be either just infront or just behind the drivers side strut mount. Look for a two wire connector with a cap on it. The cap can be either gray or yellow.
Heylookits shawn
10
Dec 12, 2007 10:42 AM
