radiator fan not working (90 crx hf w/b16 swap w no ac) please help
Old Jul 6, 2002 | 05:10 PM
Dank26's Avatar
Default radiator fan not working (90 crx hf w/b16 swap w no ac) please help
should let you know My car is an HF with an SI radiator from radiator.com
Fans not working.One sensor is pluged in to the fan.I have two more sensors with no where to plug.I assume the two are for the ac I removed.My check engine light is on and the ecu is flashing a code 6(radiator fan sensor unplugged or bad) Here is my question.
How many sensors are there for the radiator fan? 1 or 2 or even 3.
Thanks
dan
M car never over heats.Im more worried about failing e check because of check engine light.
Old Jul 6, 2002 | 06:47 PM
speedfreak420's Avatar
Default Re: radiator fan not working (90 crx hf w/b16 swap w no ac) please help (Dank26)
i have 90 hf that no longer has ac because i took it out when i did my zc swap the radiator fan has one plug. two of the three plugs r the same one runs the ac fan the other the radiator fan. the one u want should be a white plug if i'm not mistaken the two just set aside or cut off if u dont want ac. the ac fan should have another plug real close to it
Old Jul 7, 2002 | 03:50 AM
Dank26's Avatar
Default Re: radiator fan not working (speedfreak420)
thanks for the help. Looks like i'll be replacing the sensor.
Dan
Powerboss
Feb 20, 2014 11:39 AM
sleeper1g
Dec 22, 2008 07:15 AM
Blackhtch
Aug 19, 2004 06:36 PM
jazz215
Aug 23, 2003 10:48 PM
