Need Help on Buddys all Motor setup
Old Mar 2, 2008 | 05:45 PM
FastLife617's Avatar
Default Need Help on Buddys all Motor setup
Posting this up for my buddy he wrote:
i have a bulit b16 head thats milled .20
5 axis cnc ported
skunk2 stage 2 cams
copper beryllium valves seats
ferrea stainless steel valves
ferrea titanium retainers
toda high pressure valve springs
and a gsr block stock
im trying to do all motor i was wndering if i put the head on the stock bottom would their be a big difference in hp or not as much.. and im thinking on buying rods and pistons but dont know which pistons would work the best with these cams im trying not to go over 12 Compression Ratio.....
Old Mar 3, 2008 | 06:17 AM
Default Re: Need Help on Buddys all Motor setup (FastLife617)
Morning Bump
Old Mar 3, 2008 | 07:18 AM
IntegraType-R's Avatar
you can do a bunch of setups..
ls/vtec or poor mans typer is going to be your best bet, or even a b20 block..
Old Mar 3, 2008 | 01:57 PM
Default Re: Need Help on Buddys all Motor setup (IntegraType-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">you can do a bunch of setups..
ls/vtec or poor mans typer is going to be your best bet, or even a b20 block..</TD></TR></TABLE>
He is decided on the GSR block but he want to know what would be good pistons for him to use wit current set up he got and not go over 12 comp ratioi
Old Mar 3, 2008 | 02:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastLife617 &raquo;</TD></TR><TR><TD CLASS="quote">
He is decided on the GSR block but he want to know what would be good pistons for him to use wit current set up he got and not go over 12 comp ratioi</TD></TR></TABLE>
gsr
tgeorgersx
Sep 16, 2016 06:28 PM
dfinch88
Aug 5, 2010 12:46 PM
SCYRIO
Dec 22, 2004 07:21 AM
akaEsCo01
23
Sep 18, 2003 03:13 PM
