just got rear discs...
okay so i just got rear discs for $50, and from my understanding i'm going to need to get some things to complete it. so far i know i have to replace the rotors, i got energy bushings, but i've heard they seperate and take a **** on you, is this true? plus i dont know what the part is called but, its the thing thats sits inside the bushing, i'm missing that as well.
is there anything you see that i'm missing?
this is the drivers rear, and it appears to be solid and complete:
now on the passenger rear its more in pieces, i got some shots from behind:
see anything missing from the passenger side?
i also got a master cylinder, is this an upgrade?
let me know, thanks guys.
Get new brake lines and definately use the energy suspension bushings. That is a HUGE rumor that they separate. Did you get the solid ones? clean everything. Sometimes the rear trailing arms are slightly different and you might need some rear turn-style upper control arms.
search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search
i have, i've been floating around on ht for several years now. i know how to search, but never found a thread like this. so i made one so people could refer to it in the future if needed.
all i need to know is if all bolts and such are there? i will get new ta bushings, rotors, and pads. also are the brake lines usable as of now?
here https://honda-tech.com/zerothread/1916212
and all the bolts for the trailing arm are already on your car
and search for your bushing question you WILL find lots, but I would only use rubber on the rear trailing arm.
thanks man. yeah i dont even know how many times i've looked at that thread lol. i will also get these: https://honda-tech.com/zerothread/1960010
i'm still a little unsure about the internals of the setup, does it all appear to be there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drgnwagn »</TD></TR><TR><TD CLASS="quote">You got what i need , you scored a smokeing deal </TD></TR></TABLE>
I got mine for $50 at a local yard. Its the jack asses who jack up the prices and people who pay for them that determines rediculous prices.
Brewer
Jan 13, 2006 12:26 PM
B_CRUZ!
Jul 24, 2004 05:57 PM
