timing belt and tensioner
wat up
im replacing the t-belt on my b16a2 and also replacing the pistons for ctr pistons, im already getting de piston rings, but i wanted to know what else i should buy to replace the timing belt and the pistons, i heard i should buy an oil pan gasket but any tips would be appreciated.
thanks
thanks
u will also need new headgasket. new head studs. new water pump and maybe oil pump. front main seal and rear main seal.valve gasket and oil pan gasket. it depends on how u want it to be built. i replaced all the gaskets and seals when i did mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason007 »</TD></TR><TR><TD CLASS="quote">do you know a brand i should buy the stuff from or just honda oem?</TD></TR></TABLE>
i use oem honda parts , unless u are going high boost, then u will need a aftermarket headgasket. otherwise, oem is good enough.
SpecialRequest
10
Apr 14, 2015 02:45 PM
raverx3m
Dec 27, 2011 02:13 AM
Mike VR6
35
Mar 2, 2007 03:23 AM
TRE_
May 3, 2006 06:32 AM
