Oil filter sandwich adapter can this be used for external oil filter relocator???
I was wondering if any of you are familiar with oil filter sandwich adapters. It still allows for an oil filter to be in stock location but has ports....not sure if they are inlet and exit or neither/static. They say you can use it for sensors or can be used to run an oil feed line for a turbo. So I assume if there is pressure which there is one could run a secondary remote oil filter off this?
http://cgi.ebay.com/ebaymotors...h=016
I don't think that would work because theres no inlet port just outlet ports.
I ran a kit like this on my last car. http://store.summitracing.com/...w=sku
Thanks thats actually the same price as the sandwich adapter but with the lines and oil filter adapter as well. good deal. This is what I want to add:
http://www.frantzoil.com/OilFi....html
Thanks for the link on the oil relocation kit. I purchased it and am going to install this week. It mentions to use a Ford oil filter. What did you use? Is there a certain year or model of Ford for the oil filter?? Thanks in advance.
From: Where the wild things are in, NY, United States of America
Its a fram Hp-1 style filter more then likely. A gabillion auto stores have that or the same thing in a different brand, any SBF pre 93 should take the same one. Frams number is the HP-1 and K&N's oil filter is the HP-3001. Enjoy.
