Sir I or Sir II
Old Mar 2, 2008 | 12:19 PM
dragonkx's Avatar
Default Sir I or Sir II
I was wondering what is the difference between a b16a sir I and a b16a Sir II? Other than one runs on a pr3 and a p30 piston. There was like a price difference of like 500 dollars from sir I to sir II.
Old Mar 2, 2008 | 02:21 PM
zdalunatic's Avatar
Default Re: Sir I or Sir II (dragonkx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonkx &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering what is the difference between a b16a sir I and a b16a Sir II? Other than one runs on a pr3 and a p30 piston. There was like a price difference of like 500 dollars from sir I to sir II. </TD></TR></TABLE>
Sir I is OBD1 and Sir II is OBD2, other than that i dont think there is a difference!
Old Mar 2, 2008 | 02:56 PM
sorrule's Avatar
actually I think SiR I is obd0 out of the crx's civics and older integras. The SiR II is out of the JDM 92-95 civic and del Sol's. It is also OBD 1 and has a higher comp ratio and has a little more HP.
Old Mar 2, 2008 | 02:57 PM
KENetics1's Avatar
one is newer than the other, so SIRII is likely to have less mileage or in better condition maybe.
Old Mar 2, 2008 | 05:20 PM
palisoc05's Avatar
Default Re: (sorrule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sorrule &raquo;</TD></TR><TR><TD CLASS="quote">actually I think SiR I is obd0 out of the crx's civics and older integras. The SiR II is out of the JDM 92-95 civic and del Sol's. It is also OBD 1 and has a higher comp ratio and has a little more HP. </TD></TR></TABLE>
Old Mar 2, 2008 | 07:09 PM
dragonkx's Avatar
well I heard that the jdm b16 sir II has like 170 horsepower at 7600 rpm and alittle torque but the sir I has 10 horsepower less than the sir II like around 160 at 7600, just making sure. Other than that 10.4.1 and 10.2.1 compression, everythign else pretty much looks the same, but i've heard that that sir II has cams that are alittle bit more agressive , but even so it couldnt of added 10 extra horsepower.
Old Mar 2, 2008 | 07:34 PM
sorrule's Avatar
Default Re: (dragonkx)
I'm not sure what the exact specs of the motors are but the comp ratio is correct and I do think the SiR II has a bit more aggressive cams. The cam probably is more efficient up top and a long with the slight increase of compression, the extra 10hp seem pretty achievable. Honda can engineering some pretty amazing things.
Old Mar 2, 2008 | 09:11 PM
palisoc05's Avatar
first gen SiR 10.2:1.... SiRII 10.4:1
Old Mar 3, 2008 | 07:22 AM
89s1's Avatar
Default Re: (palisoc05)
the sirII gets a better intake manifold.
more compression 10.4 vs. 10.2
different valve cover
different/better pistons
cams are the same IIRC, the extra power 170ps vs. 158ps is from the bump in compression and the better intake manifold.
I've owned both the sirII was more fun for sure.
Old Mar 3, 2008 | 07:24 AM
89s1's Avatar
Default Re: Sir I or Sir II (zdalunatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zdalunatic &raquo;</TD></TR><TR><TD CLASS="quote">
Bad information
Edit: zdal already corrected you...
Old Mar 3, 2008 | 07:37 AM
KENetics1's Avatar
sirII also comes with hydro tranny
Old Feb 26, 2022 | 08:11 AM
caincrx's Avatar
Sir & sir 2 are trim levels that came on both ef & eg hatchs. Sir 2 got more addon like lsd & extras & G2 b16a cams have .3 more lift on the intake & 5° duration On intake & 2° on exhaust more aggressive ecu turning, .2 more CR & better intake is where the extra 10 HP comes from.
rockycat
Nov 20, 2017 03:28 PM
da9leo
Mar 14, 2011 08:23 PM
hondahead21
May 4, 2008 04:52 AM
littlebill
Nov 22, 2006 08:21 PM
VTECcnIT
Feb 6, 2006 03:08 PM
