12.5:1
Old Mar 2, 2008 | 11:13 AM
wesley_925's Avatar
Default 12.5:1
can i run a 12.5:1 piston on pump gas? what determines wheter it can run on pump gas or not?
Old Mar 2, 2008 | 11:32 AM
oskie's Avatar
Default Re: 12.5:1 (wesley_925)
no way thats happenin
Old Mar 2, 2008 | 11:40 AM
quicksilver1689's Avatar
i ♥ snails
compression, chamber design, quench/squish design, dynamic compression, octane of the pump gas, ignition timing, afr's, yada yada yada
Old Mar 2, 2008 | 12:22 PM
Thateguhate's Avatar
Default Re: 12.5:1 (oskie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oskie &raquo;</TD></TR><TR><TD CLASS="quote">no way thats happenin</TD></TR></TABLE>
dont bother posting if your going to be incorrect when doing so..
yes you can, its all in your tune. Im using a walbro 255iph fuel pump and 370cc delphi injectors and I have no knocking or pinging, not at high rpm or at all period..
btw, im tuned on 91 octane, so depending on where you live you might have a better resource for higher octane where you may live..
Old Mar 2, 2008 | 04:09 PM
Jap_Spec_Imports's Avatar
Default Re: 12.5:1 (Thateguhate)
im running ctr pistons in my b18c5 block. No problems at all
civic_66
23
Oct 25, 2008 05:22 PM
THC07
May 29, 2007 07:26 PM
Thepanda
May 10, 2006 10:39 AM
integlspwr2k
Aug 2, 2005 07:15 PM
216.226.142.95:27016
Jun 14, 2003 12:15 AM
