quick timing question
Old Mar 2, 2008 | 09:47 AM
LS AzZkIkr's Avatar
Default quick timing question
i have just finished building a lsvtec for boost and i am running into a timing problem. i have a gsr timing belt and gsr water pump and oil pump and the timing belt will not allow the cams to stay in the proper position along with the crank. its very strange the belt will tighten up on the cams but the crank will not line up.
Old Mar 2, 2008 | 06:52 PM
blkb18's Avatar
Default Re: quick timing question (LS AzZkIkr)
I am not sure, but is the timing belt pulley on the crank the same on a ls as a gsr, maybe the number of teeth are different?
Old Mar 3, 2008 | 06:50 AM
LS AzZkIkr's Avatar
Default Re: quick timing question (blkb18)
i have changed that also and it still will not line up properly. this is very confusing
Old Mar 3, 2008 | 08:58 PM
nam3less's Avatar
Stock Cams and Stock Cam Gears?
Old Mar 3, 2008 | 09:06 PM
all-mtr-teg's Avatar
Are you sure you're tensioning the timing belt right? Also, has the block been decked or the head milled?
Old Mar 4, 2008 | 07:45 AM
blkb18's Avatar
I just did a crv timing belt at work a few months ago, there is a suggested sequence in the repair manual for the installation of the tbelt. It tells you to lock the cams in there proper position, then put the belt on a certain pulley first and so on. It isnt 100% neccesarry to follow it but it makes it a whole lot easier.
Old Mar 4, 2008 | 11:47 AM
nam3less's Avatar
Default Re: quick timing question (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you're tensioning the timing belt right? Also, has the block been decked or the head milled?</TD></TR></TABLE>
Valid point on the decked or milled comment... cam gears too &gt;.&lt; I've installed so many aftermarket cam gears that sometimes line up... and some times do not. So let us know
Old Mar 4, 2008 | 04:33 PM
LS AzZkIkr's Avatar
Default Re: quick timing question (nam3less)
i have skunk2's on it now and i tried to time it with the factory gears and it just wont line up. i dont know if the head or block has been cut but i do know that this belt is a p72 gsr bran new and the water pump is also. the teeth on the cams are just very slightly off. i am just assuming that i can get this to go away by adjusting the gears but i just wanted to know if the lsvtec has a problem or not.
Old Mar 4, 2008 | 09:16 PM
Since LS Block is a little shorter than a GSR I believe the timing will be slightly off right?
Old Mar 5, 2008 | 03:24 PM
LS AzZkIkr's Avatar
that is what i have heard from several people but i dont believe that they have any experience with a lsvtec.
Old Mar 6, 2008 | 06:38 AM
If you haven't already, maybe do a search or post in the "all motor" forum. Good luck
lllelementlll
Oct 15, 2016 04:49 PM
f20beme
Apr 13, 2015 04:34 AM
Bright13
Classic Hondas
Mar 26, 2009 02:05 PM
fatpride111
10
Nov 20, 2008 07:05 AM
turboedsupe
Sep 19, 2008 04:32 PM
