NEED: Suspension Technique front swaybar help.... for..EK without factory swaybar.
if anyone has experience with putting a sway bar on a car WITHOUT a factory sway bar, help me. The Suspension Technique front swaybar kit comes with a bracket that is supposed to go over the control arm.
it comes with a spacer but it seems impossible to fit the spacer in the bracket and still have the bracket in a position to connect with the sway bar. how is it suppose to go in?
if the spacer is in the bracket, the bracket dosn't fit in close enough to the swaybar to connect to it.
this is how it SHOULD BE...
but this is the only way i could get it to fit over the arm...
with the spacer on, it fits on the arm more towards bolt #14 but the end link is in an awkward position
without the spacer, it can fit near bolt #17 and everything lines up.
any help guys?
it came with a spacer so i would like to use it correctly. but as of now, im not using the spacer.
if it's too confusing, i'll take more detailled pictures later.
Modified by importnoodles at 10:41 AM 3/2/2008
Modified by importnoodles at 10:42 AM 3/2/2008
Modified by importnoodles at 10:43 AM 3/2/2008
any help guys?
denshu
Jul 5, 2003 02:16 PM
