clutch feeling
Old Mar 1, 2008 | 08:42 PM
infamouskillas's Avatar
Default clutch feeling
so lately idk i think my clutch is startin to wear out cuz its just not feeling the same anymore...basically i feel like its easing up and not as stiff as it was before or something...now besides it wearing out, idk what else could cause this...what do you guys think...yeah i'm 17 years old...its my first car, so basically idk what a fresh clutch and a worn out clutch feels like...need help pls...thanks a lot
Old Mar 1, 2008 | 08:52 PM
seskill's Avatar
Default Re: clutch feeling (infamouskillas)
do you hold your foot on the cluch when your at a light. i think that the pressure plate is bad in mine. i had just bought a 95 gsr. my cluch is very soft. but it grabs low.
Old Mar 1, 2008 | 08:54 PM
Default Re: clutch feeling (seskill)
now basically i watch the other light and see when it turns red...right before it turns red...i put it in first and then hold the clutch for a little until it turns green...i'd say maybe 4 - 6 seconds is how long i hold it at a light...before my clutch catch low, but now i gotta release it more to for the gears to catch if that makes sense...what do you think it is?
Old Mar 2, 2008 | 01:19 PM
TX_RSX254's Avatar
could possibly need to bleed the clutch fluid... does it feel kinda soft?
Old Mar 2, 2008 | 01:21 PM
Default Re: (TX_RSX254)
yeah it feels soft now...like i said not as stiff...i just figured it could be the clutch wearin out...so u think i have to bleed the clutch fluid in there??
Old Mar 2, 2008 | 02:55 PM
gsilnc's Avatar
Default Re: (infamouskillas)
i dont know about the third gens but on my da the clutch is adjustable just under the hood.
Old Mar 2, 2008 | 03:25 PM
Jimmy's Avatar
Global Moderator
I had a similar problem in my teg also..
My clutch started feeling very soft.. and engaging/disengaging different at different points..
I checked my clutch fluid reservoir and the fluid was near empty.. Which is common with honda's and acuras..
The clutch master cylinder tends to leak around the seal up around the clutch pedal.. which will need to be replaced..
Check to see around the top of the clutch pedal inside the car to see if you see any fluids around there..
Check your clutch fluid.. and if it needs to be topped off.. top it off with dot 3 or dot 4 brake fluid..
Then try bleeding your clutch..
there's a 8mm nut on the slave cylinder.. same process as bleeding brakes..
Eddieman201
Dec 13, 2008 02:31 PM
tripledubz
Jan 26, 2008 07:05 AM
CaMiKaZi
Apr 1, 2003 03:40 PM
Brett
Nov 15, 2002 01:18 AM
jeebusm3
May 5, 2002 12:20 AM
