d15b8 with d16y8 head which ecu and timming belt question?
Old Mar 1, 2008 | 06:47 PM
solsi2000's Avatar
Default d15b8 with d16y8 head which ecu and timming belt question?
anyone know which ecu and timing belt to use for this setup? ive searched but not much on these 2 mostly just d16z6 head and d15. lmk thanks
Old Mar 2, 2008 | 08:28 AM
solsi2000's Avatar
Default Re: d15b8 with d16y8 head which ecu and timming belt question? (solsi2000)
bump
Old Mar 2, 2008 | 12:59 PM
solsi2000's Avatar
ttt no one has this setup?
Old Mar 2, 2008 | 01:21 PM
thursday's Avatar
i'm assuming this is in a 92-95?
if my assumption is correct then you should be able to use a b8/b7/b2/b1 timing belt and p28/ p08 or chipped and vtec'd p06 ecu.
now i may be wrong but i believe if you use the stock y8 cam gear your cam timing is going to be off...i think if you used a 88-95 gear it will correct this...
Old Mar 3, 2008 | 01:42 PM
solsi2000's Avatar
Default Re: (thursday)
werd thanks! yeah its a d15b7 i mean. 92-95
Old Mar 3, 2008 | 02:31 PM
Dasfinc's Avatar
Default Re: (solsi2000)
I had this EXACT setup, Check my sig for the write-up
*CLICK THIS* https://honda-tech.com/zerothread/2147115
D16Z6 timing belt, I ran a Chipped P05 ECU converted to Vtec. http://www.phearable.net, sent my stock ECU in with $100 and got back a ECU for that setup.
Be aware of the 'half tooth' error with Y8 heads on D15 blocks, the Z6 mini-me is ALOT easier and alot more reliable.
Old Mar 3, 2008 | 08:19 PM
solsi2000's Avatar
Default Re: (Dasfinc)
damn but could it be fixed with an adjustable cam gear? thanks for the link
Old Mar 3, 2008 | 08:21 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsi2000 &raquo;</TD></TR><TR><TD CLASS="quote">damn but could it be fixed with an adjustable cam gear? thanks for the link</TD></TR></TABLE>
Yes, it can. I'm the person that made the article in that link, so if you have any questions feel free to ask or PM me.
Old Mar 3, 2008 | 08:44 PM
thursday's Avatar
oh yeah i forgot generally you use the timing belt for the head you are using (generally)
my bad
BenJovan
Apr 6, 2013 08:02 AM
s1ngle
Jun 17, 2010 07:47 AM
GoKOOLjeff
Jan 7, 2008 11:36 PM
2.2
13
Oct 28, 2003 12:03 AM
