mini me wont start
Old Mar 1, 2008 | 12:32 PM
Rease3's Avatar
Default mini me wont start
the past couple days i been swaping a z6 head on my a6 block and now it is all back together and it wont start..obd0 chipped pr4 with z6 map. all it does is crank over but wont start.
Old Mar 1, 2008 | 12:52 PM
Rease3's Avatar
Default Re: mini me wont start (Rease3)
bump car has been down for a a week
Old Mar 1, 2008 | 02:04 PM
Ilovemyef9's Avatar
Are the dizzy wires hooked up right, have u checked for any spark...
Old Mar 1, 2008 | 02:26 PM
Rease3's Avatar
Default Re: mini me wont start (Ilovemyef9)
does it go from the top of the dizzy?
13
42
and all of them get spark but 1 so ima try to get new wires today and c if thats the case
Old Mar 1, 2008 | 03:08 PM
Rease3's Avatar
ttt
Old Mar 1, 2008 | 03:36 PM
TreWatts's Avatar
check for compression, fuel, and spark. a car needs those three things to start.
what got me (3 times actually) during my last project was the timing being off by a few teeth. turned out to be a very expensive 3 mistakes.
Old Mar 1, 2008 | 04:30 PM
Rease3's Avatar
Default Re: mini me wont start (TreWatts)
what u took it to the shop and got it fixed or what..
Old Mar 1, 2008 | 07:01 PM
civickiller's Avatar
i could be wrong but isnt it
34
12
Old Mar 1, 2008 | 07:11 PM
Tippyman's Avatar
Default Re: mini me wont start (civickiller)
Check for:
Spark, Timing, Compression, Fuel.
If you have all those, it will at least run. My bet is that chipped ecu of yours.
Old Mar 1, 2008 | 09:55 PM
Rease3's Avatar
Default Re: mini me wont start (Tippyman)
xencoron chipped my ecu its good. my timing is way off an I don't kno how to do it. what's a good way to find out if my crank pulley tdc so I can line up the cam? I have spark and fuel.
Old Mar 2, 2008 | 12:43 AM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">i could be wrong but isnt it
34
12</TD></TR></TABLE>
Looking at the pictures, the sparkplug wires are wrong. Also, when using an A6 distributor on a Z6 head, you will need to grind out the bolt holes so that you have the extra adjustability to get the ignition timing as close as you can to stock spec. As the distributor sits in the picture, the timing is really off. Converting to OBD1 and using a Z6 distributor and P28 ecu would have been a better option. But, you can still have a decent running car with your set-up, it just needs some adjustments.
Old Mar 2, 2008 | 06:43 PM
Rease3's Avatar
Default Re: mini me wont start (Redline130)
ok well i got it to start but my timing is still off going to check it more. do i use the y7/y8 cam gear or keep with the z6 cam gear?
Old Mar 3, 2008 | 10:20 AM
TreWatts's Avatar
[QUOTE=Rease3]what u took it to the shop and got it fixed or what..[/QUOTE/]
not the car, the head. i had to rip the head back off and take it to the machine shop... twice. the thrid time it happened i just bought a new head off my friend for 50 bucks and called it a day.
Old Mar 3, 2008 | 06:26 PM
Rease3's Avatar
ok well i got it to start fixed the timing but now it sound like a sti under full boost..i think thats bad..
Old Mar 3, 2008 | 07:10 PM
beana's Avatar
check your ignition timing should be 16 degrees btdc
Old Mar 3, 2008 | 07:32 PM
Rease3's Avatar
Default Re: mini me wont start (beana)
my dizzy is obd0 dizzy and its in the stock position
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
gsrboost737
Apr 16, 2009 11:38 PM
kelviiv
Dec 17, 2008 11:19 AM
bonestock92si
38
Aug 30, 2004 10:02 PM
t3to4e
Jan 7, 2004 05:00 AM
