SOHC y5 hx help!!!!!!!!!!!!!
Old Mar 1, 2008 | 08:44 AM
uenolove's Avatar
Default SOHC y5 hx help!!!!!!!!!!!!!
hey guys i couldnt find the exact answer i needed by searching... .
i just wana throw a y8 or a z6 head on my y5 block... what am i going to need??? i have a z6 head now but i have been told that i need a dizzy and stuff... i would search dseries.org but my work computer has blocked it
Old Mar 1, 2008 | 08:52 AM
ifIexplode's Avatar
https://honda-tech.com/zero...age=1
Old Mar 1, 2008 | 09:20 AM
uenolove's Avatar
ummm where does that talk about what i will need for preexisting vtec block????i didnt see it , did you??? i just wanna know what i need to run y8 or z6 on y5.. y5 is a vtec E... i just want it to be normal.
Old Mar 1, 2008 | 10:38 AM
uenolove's Avatar
still havnt found help
Old Mar 1, 2008 | 03:40 PM
big-cat's Avatar
been covored 23492834723894723089472348907 times. to do it exacly right you are going to basically need to rebuild your whole engine if the y8's and z6's use a different piston.
anyways you are going to need a the wiring harness to match the head. the timing belt to match the head and more researching because it is all over the web.
Old Mar 1, 2008 | 03:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (big-cat)
» Search Results
Your search for mini me returned 279 results.
dippy
Feb 26, 2009 07:33 AM
ej6hatchie
Oct 29, 2008 09:38 AM
mattcivic
12
Mar 20, 2007 04:19 PM
props_honda85
Sep 19, 2005 11:24 AM
Soundwave9900
Oct 18, 2002 10:20 AM
