critics on my own aluminium radiator weldings ?
Old Mar 1, 2008 | 06:15 AM
hondaapi's Avatar
Default critics on my own aluminium radiator weldings ?
Can some people rate my welds on these aluminium radiator?
Thanks
http://www.pictureupload.de/pi...3.JPG
http://www.pictureupload.de/pi...2.JPG http://www.pictureupload.de/pi...2.JPG
Old Mar 1, 2008 | 06:38 AM
B20C1T's Avatar
Default Re: critics on my own aluminium radiator weldings ? (hondaapi)
did you do the entire thing or is there one aera you want us to look at?
where the endtank meets the fins looks a little worse than the actual end tank but all in all very good.
what type and size tungston are you using and what size filler rod?
They say if you can do aluminium u can do anything, well im great at aluminum and i suck at steel.
Old Mar 1, 2008 | 08:18 AM
hondaapi's Avatar
Default Re: critics on my own aluminium radiator weldings ? (B20C1T)
Yes, I build the complete radiator.
I just bought the core and buildt the tanks completely on my own. This is my second radiator that I´ve buildt.
The filler I used was 2mm (think 0.078inch).
The problem is that the material I choose for the tanks is 2mm and the corematerial is just 1mm (0.04inch). So it starts to melt faster than the tank and I have to "hurry up" with my line.
Any idea how to make this area more consistent?
Old Mar 1, 2008 | 09:52 AM
snowseeker's Avatar
Torch angle will help you with welding the thinner stuff to the thicker stuff. Turn the angle of the torch tward the thicker stuff a little more.
Did you leak test it? Should be fine if it doesn't leak.
Old Mar 1, 2008 | 04:04 PM
silly sohc's Avatar
When I weld different thickness of aluminum I heat the thicker items first with a propane torch.... then when welding I keep the majority of the puddle on the thicker material. Helps a lot.
Old Mar 2, 2008 | 06:11 AM
B20C1T's Avatar
I do something similar to that but mainly i just point the torch to the thicker metal.
blitzman
Feb 26, 2016 11:44 AM
rudebwoy
May 11, 2014 07:43 PM
The sweed
Nov 14, 2008 11:51 AM
Rotary knight
Apr 18, 2005 10:59 AM
