MY EP3 needs to lower more? or function!!
Old Mar 1, 2008 | 03:02 AM
Endemic's Avatar
Default MY EP3 needs to lower more? or function!!
i getting words from peeps lately "YOU NEED LOWER IT MOARR!!!" i was like damn there's no way it will be rubs like a bitch so i am not sure.. i am into function more. the setup is 225/45/17 with 2in dropped.
make a comment will be helpful!
Old Mar 1, 2008 | 03:31 AM
Endemic's Avatar
^^^ old pic though..
after nearly 500 miles later it went a little low a bit i took a pic recently.
Old Mar 1, 2008 | 03:33 AM
SuperSonikBluEK's Avatar
Default Re: (Endemic)
do you have any better pics of your car?? like maybe a side shot? but its your car bro...do with it wat you want
Old Mar 1, 2008 | 03:46 AM
OAFA's Avatar
Default Re: (SuperSonikBluEK)
it look enought low. 225 is wide so you will rubs.
But if you really want to be more low. just put 1 degre negativ camber in the rear and 0.5 degre negativ in the front. it will help a little bit. roll you fendre in the rear.
Old Mar 1, 2008 | 04:09 AM
Endemic's Avatar
Default Re: (OAFA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSonikBluEK &raquo;</TD></TR><TR><TD CLASS="quote">do you have any better pics of your car?? like maybe a side shot? but its your car bro...do with it wat you want </TD></TR></TABLE>
Yeah. but i am curious. thanks bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OAFA &raquo;</TD></TR><TR><TD CLASS="quote">it look enought low. 225 is wide so you will rubs.
But if you really want to be more low. just put 1 degre negativ camber in the rear and 0.5 degre negativ in the front. it will help a little bit. roll you fendre in the rear.</TD></TR></TABLE>
Yeah that's what i thought too. thanks.
Old Mar 1, 2008 | 05:24 AM
misha's Avatar
thowse look good slammed
Old Mar 1, 2008 | 06:18 AM
The Collin's Avatar
Looks fine to me the way it is. IF you're for function, then why mess with it? Plus with those meaty tires, you're at the right height. Leave it.
Old Mar 1, 2008 | 06:33 AM
BLANCOh22a4's Avatar
Default Re: MY EP3 needs to lower more? or function!! (Endemic)
don't care...it's your money do what you want
Old Mar 1, 2008 | 06:53 AM
Boost_V's Avatar
Default Re: MY EP3 needs to lower more? or function!! (BLANCOh22a4)
You'd be better off getting a lip first.
Old Mar 1, 2008 | 07:22 AM
SKRIMPS's Avatar
looooowweerrr! i rolled rear fenders on my ep3.
Old Mar 1, 2008 | 07:34 AM
what gsr's Avatar
Default Re: (SKRIMPS)
slammed cars look rediculous.. it looks like you have a good height going on.. id leave it the way it is.. but keep in mind that this is honda-tech and you will get 3 pages of nothing but "slam it" commnets. i mean this is the a/c forum so appearance is more to most of these people then the way their car functions.
Old Mar 1, 2008 | 07:43 AM
WERD up's Avatar
Default Re: (what gsr)
it looks good the way it is now, but i'd slam it
Old Mar 1, 2008 | 07:44 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: (WERD up)
Leave it, it looks good as is.
Old Mar 1, 2008 | 07:45 AM
98civichb's Avatar
in this case Function &gt; Form
Old Mar 1, 2008 | 07:55 AM
genetsang's Avatar
Default Re: (98civichb)
leave it. looks good the way its at. in my opinion, Not worth the headache with it slammed to the ground. Unless you want to do charity work and help your city plow its streets, the slam it. Otherwise, its perfect the way it is.
Old Mar 1, 2008 | 08:01 AM
Endemic's Avatar
yeah i am gonna go to leave it.
thanks for the comments
Old Mar 1, 2008 | 08:04 AM
Newborn_'s Avatar
You know it makes sense.
Old Mar 1, 2008 | 01:02 PM
ITR_cam's Avatar
looks good on springs, but if it was on coilovers id drop it a little more, hot EP son!
Old Mar 1, 2008 | 02:34 PM
Endemic's Avatar
Default Re: (ITR_cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR_cam &raquo;</TD></TR><TR><TD CLASS="quote">looks good on springs, but if it was on coilovers id drop it a little more, hot EP son!</TD></TR></TABLE>
it's megan racing lowering springs. thanks.
Old Mar 1, 2008 | 02:45 PM
95greenlude's Avatar
those tires look HUGE!
Old Mar 1, 2008 | 02:52 PM
barely4dr's Avatar
Default Re: (99_hb_on_air)
Keep it at THAT height
Function &gt; Form
edit:
springs are ehh...coilovers are 'beta pho yu'
Old Mar 1, 2008 | 02:56 PM
mannydc5's Avatar
SLAM IT!!!!
Old Mar 1, 2008 | 03:00 PM
dangthemang's Avatar
Default Re: MY EP3 needs to lower more? or function!! (mannydc5)
DUMP IT
Old Mar 1, 2008 | 03:08 PM
Thateguhate's Avatar
Default Re: MY EP3 needs to lower more? or function!! (dangthemang)
If you want a functional car, without a dented oil pan, dented exhaust and overall better ride I would not suggest "slamming, or dumping" it..
Id go about another inch tops, and see where it leaves you. How low a car is all depends on the drivers ability to not screw up. Its nice for show cars, and just looks pimp, but if you like twisties etc... I would have to say no..
Old Mar 1, 2008 | 03:13 PM
Koolaid_Chris's Avatar
Default Re: MY EP3 needs to lower more? or function!! (Thateguhate)
if your rocking the stock A3, slammm it.. i mean unless you plan on doing a crushal build in where SLAMMING it will ruin the function
