thinking of getting a megan header for h23 but what gasket?
Old Feb 29, 2008 | 09:31 PM
otsegolectric's Avatar
Default thinking of getting a megan header for h23 but what gasket?
I heard they have problems with gaskets at the cat. Si what gasket should i do to not have the problem? any better gaskets that i could use?
Old Mar 1, 2008 | 06:33 AM
vlang29's Avatar
Default Re: thinking of getting a megan header for h23 but what gasket? (otsegolectric)
I've had no problem with the Megan gaskets sealing new. However, after removing and installing it again, the gasket where the two header pieces come together, splits apart.. I used high temp gasket sealer and haven't had any leaks since
Old Mar 1, 2008 | 11:46 AM
Default Re: thinking of getting a megan header for h23 but what gasket? (vlang29)
ok thinking of getting a new gasket because the header i'm getting is used with a blown gasket so what do you think i should get? like replacement megan one or another type?
Old Mar 1, 2008 | 02:11 PM
vlang29's Avatar
i've seen gasket kits for the cheap ebay header, which IIRC, will work fine with a megan
Old Mar 1, 2008 | 02:23 PM
Acidcrakker's Avatar
I have megan header. Ive unistalled and reinstalled numerous times. The gasket does split into like three diffrent layers, but with some regular motor oil and proper tourqing sequence, Ive not had a problem with reusing the gaskets over and over again
SuciaEk420
Jan 1, 2012 03:29 PM
1994PreludeSi
Jul 11, 2007 10:33 PM
jay di em02
Jan 28, 2007 11:00 AM
92TEGsrSC
Jul 29, 2003 05:57 PM
