I need help guys on Ctr Piston or Itr Piston with ctr cams head
Old Feb 29, 2008 | 08:20 PM
eg6-trans's Avatar
Default I need help guys on Ctr Piston or Itr Piston with ctr cams head
Can i run itr cams with my ctr head. Will my motor be blown? is it a good setup? CAN you guys tell me how much compression does itr piston has. Its 84.50 bore. Plz help before i buy it. Ty so much any suggestion would work fine. Ty
Old Feb 29, 2008 | 11:04 PM
Seminole's Avatar
Default Re: I need help guys on Ctr Piston or Itr Piston with ctr cams head (eg6-trans)
most of your questions can be anwserd using the search button...
ITR CP ~ 11.5:1
Yes you can use ITR pistons with CTR cams.
Old Mar 1, 2008 | 09:02 AM
King V's Avatar
With your bore, ITR USDM pistons, OEM head gasket, and using a B20 deck height, I got 11.515464:1.
http://www.c-speedracing.com/h...c.php
Try this next time.
EGtypeR408
Oct 12, 2010 01:12 AM
eg6-trans
Feb 29, 2008 10:40 PM
todab17c
15
Feb 25, 2008 10:47 AM
92integraVTECgsr
Nov 18, 2007 02:51 PM
Mark
Nov 18, 2003 03:12 AM
