5th gen making whistling noise
Old Feb 29, 2008 | 06:43 PM
twiztid00002's Avatar
Default 5th gen making whistling noise
yeah so it started today. when i get past like 2500 rpms somethin makes a whistling noise. its hard to tell where its coming from, but it sounds like an air leak. exhaust or intake?
Old Feb 29, 2008 | 06:52 PM
ludekid4323's Avatar
Default Re: 5th gen making whistling noise (twiztid00002)
that means you have a special edition tubo prelude jp but does it have a stock intake box?
Old Feb 29, 2008 | 06:54 PM
Default Re: 5th gen making whistling noise (ludekid4323)
i got a k&n short ram on it now and its been on it for like 2 months along with the exhaust for around 2 months and nothing else done to it that would make that noise
Old Feb 29, 2008 | 07:00 PM
Sampsonite987's Avatar
Is it a constant tone, or does it change throughout the RPM range? Have you checked your belts? If you have any threads coming loose then it can make a whistling sound.
Old Feb 29, 2008 | 07:02 PM
Default Re: 5th gen making whistling noise (Sampsonite987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sampsonite987 &raquo;</TD></TR><TR><TD CLASS="quote">Is it a constant tone, or does it change throughout the RPM range? Have you checked your belts? If you have any threads coming loose then it can make a whistling sound.</TD></TR></TABLE>
the higher the rpms the faster it whistles. and what do u mean by threads?
Old Feb 29, 2008 | 07:17 PM
The belts (AC/Alt, PS) are strengthened by a type of string or thread on the inside, so if your belts are old, or you have a bur on one of your pulleys it will make the belt start to come apart, usually on one edge. I would check edges of the belts all the way around. This may not be the same whistling sound that you are hearing, but it is worth a look.
Old Feb 29, 2008 | 07:27 PM
alright thanks ill check it tomorrow and can i just turn the belt with my hand or is that bad for the motor?
Old Feb 29, 2008 | 07:32 PM
Your not going to be able to turn it without some force. I would try to run my finger along the edges to see if you can feel anything, and also check it when it is running. If it is indeed the belt that is the culprit, it shoudn't be too hard to find the problem. BTW, have you checked all your vacuum hoses and made sure your short ram hasn't started to vibrate lose at any of the connections. Just something else to keep in mind when you are under the hood.
Old Mar 5, 2008 | 03:53 PM
ok, so i found out that the whistling turbo sounding noise only happens when my lights are on and it started after i got my head unit but not right after, like about a week later i think. now what do u guys think?
Old Mar 5, 2008 | 08:36 PM
Sounds like your alternator may be going bad. You should have it checked to make sure it is producing enough juice. Bearings could be going out.
rodondoaccord
Apr 15, 2014 06:42 PM
jr408
Mar 19, 2008 09:39 AM
es_squared
Mar 15, 2007 06:48 PM
Baron55
Nov 26, 2005 09:41 AM
95greenteg
Mar 10, 2005 06:02 PM
