VERY high idle with the iacv hooked up wtf!?!?!?
Old Feb 29, 2008 | 06:31 PM
97ekb18b's Avatar
Default VERY high idle with the iacv hooked up wtf!?!?!?
ok i just got it running and noticed that the iacv was not hooked up at all, i hooked it up but i have a idle around 3500 now, is this a bad iacv or what please help
EDIT this is in my 97 coupe which has a b18b, im running a obd2 engine harness and a obd1 ecu(p75) with the proper jumper harness.
Old Feb 29, 2008 | 06:37 PM
z6hatchboy's Avatar
Default Re: VERY high idle with the iacv hooked up wtf!?!?!? (97ekb18b)
Any codes? Unplug the MAP sensor and see what happens.
Old Feb 29, 2008 | 06:40 PM
97ekb18b's Avatar
Default Re: VERY high idle with the iacv hooked up wtf!?!?!? (z6hatchboy)
were would the map be located i honestly havent seen one i dont think and yes i only have a code when its un hooked which is obviously why but when its hookedd up no cel but the 3500 rpm idle
Old Feb 29, 2008 | 07:05 PM
97ekb18b's Avatar
bump!!!!
Old Feb 29, 2008 | 07:08 PM
ImportCracker88's Avatar
when did the high idle start, it its been high before it was hooked up, vacuum leak.
Old Feb 29, 2008 | 07:18 PM
97ekb18b's Avatar
Default Re: VERY high idle with the iacv hooked up wtf!?!?!? (ImportCracker88)
it just started when i hooked the iacv up when its unplugged it idles around 1500rpm but with a cel for it, but when i hook it up it goes to 3500 rpm
Old Feb 29, 2008 | 07:30 PM
crazyguy's Avatar
map sensor is attached on top of the throttle body and try to clean iacv with brake cleaner.
Old Feb 29, 2008 | 07:35 PM
97ekb18b's Avatar
Default Re: VERY high idle with the iacv hooked up wtf!?!?!? (crazyguy)
u have a skunk2 tb is it on the bottom of it on those i beleive it is could i possible have the tps plug and the map backwars they are the same type of plug????
Old Feb 29, 2008 | 08:35 PM
F Bomb's Avatar
could be your FITV(fast idle thermo valve) which is normally located under the tb... might try to check the diy's on here and clean them both out, east step and won't hurt only help even if its not the problem
Old Feb 29, 2008 | 09:30 PM
97ekb18b's Avatar
Default Re: (F Bomb)
i dont think this engine has one all iit has on the tb is the tps and the map, and it has the iacv and the ais on the intake thats it, i do have just a peice of hose going from the pvc valve to the breather that might be leaking do you think this could cause the high idle there also might be some air in the system!!
Justinmnhall
22
Sep 6, 2013 03:40 PM
twocross
29
May 3, 2011 01:03 PM
92eg_b16
Dec 13, 2007 12:26 PM
SoHov
Oct 28, 2005 10:16 AM
streetlvlhatch
Mar 30, 2004 05:08 PM
