how do u adjust a cable clutch
Old Feb 29, 2008 | 03:14 PM
BLKHB89's Avatar
Default how do u adjust a cable clutch
i have a 89 civic si. i need to adjust my clutch cable. where can i find the adjuster?
Old Feb 29, 2008 | 03:24 PM
hammergunner's Avatar
Default Re: how do u adjust a cable clutch (BLKHB89)
right on the cable itself
under the hood, on the tranny where the cable is connected to the tranny
theres is a big round black twisting ***
(ALWAYS WARE GLOVES WHEN THE MOTOR IS RUNNING)
turn the *** till you feel the clutch is just right for you
turn left to loosen, right to tighten
Old Feb 29, 2008 | 03:58 PM
janz3n's Avatar
Default Re: how do u adjust a cable clutch (hammergunner)
correct.. and just tomake it more clear. the cable for the clutch is between the tranny and the rad.
Old Feb 29, 2008 | 04:33 PM
grog's Avatar
Default Re: how do u adjust a cable clutch (janz3n)
dont over tighten it, you need to leave between 1/16 and 1/8 of inch of freeplay. meaning you should be able to pull the clutch arm (at the end of the cable) up slightly.
if you overtighten it, you will wear the clutch out faster.
Modified by grog at 9:06 AM 4/12/2008
Old Apr 12, 2008 | 07:45 AM
sitenabe's Avatar
So to tighten the clutch cable i need to turn it to the right. My clutch is almost worn out., but i keep adjusting it just to save money
Old Apr 12, 2008 | 08:17 AM
grog's Avatar
Default Re: (sitenabe)
Yes turn it to the right until the clutch release arm has just a tiny bit of free play.
To get an idea of how loose your clutch is at and where it needs to be, before you adjust it pull up and down on the clutch release arm. It should only have a tiny bit of wiggle room. Tighten the cable until the arm is all the way up (up as far as you can pull on it by hand) then back it off just a hair. if its too tight your clutch will rub on your pressure plate causing premature wear.
hatchinprogress
Feb 15, 2006 10:22 AM
lina sok
Sep 24, 2004 03:22 PM
JFG Kevin
Mar 24, 2004 06:42 PM
.nate
Sep 12, 2002 12:47 PM
