Dyno Results
H22a
BPI velocity Stack
AEM 3 inch intake
68mm AEBS TB
Accord Euro R manifold plenum portmatched to TB and runners ported
PP head
3 angle valve job on intake and radius on exhaust
Skunk2 Stage 1 Cams
Supertech Flat faced valves
Supertech valve springs
Supertech titanium retainers
Single Layer Headgasket
KaizenSpeed BalanceShaft Eliminator kit
Lightweight Flywheel
UR ultra R crank pulley
Camp1320 header (open)
Modified by lude98SH at 2:16 PM 2/29/2008
The car was tuned by Jeff Evans.
As for tuning software im using an s300j with a jdm p72
Fuel system im running stock lines, a walbro 255, aem fuel rail, RC 550s (overkill i know but i had them already)
I also had an aem FPR but it had a broken diaphragm, so I didnt have time to send it back and get a new one before my tuning date.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool »</TD></TR><TR><TD CLASS="quote">Those are some nice results! How in the world are you getting 175 lbs of torque? That is truly amazing. Is this a jdm h22 or usdm? I am sure ur car flys!</TD></TR></TABLE>
I was thinking the same thing when i saw the numbers. Its a jdm h22a
WOW! Nice power dude, Jeff Evans Dynapack is right ther with dynojets if anyone doesnt know. SO he should make the same numbers at a dynojet.
This is a awsome setup! How come you didnt go with more aggressive cams?
Again great power, and this is in a stock JDM h22 bottom end right?
Props dude, i see this car deep in the 13s.
well i got the cams for a decent price brand new so i just figured i would try them. And originally it was going to be a very mild build, on my h22a4. Im debating on some pro1s right now if i can find them for a good price. They seem like they would fit perfectly with the build.
Yes it is a stock h22a bottom end
wouldnt change a thing man. Go with different cams when you go with more compression.
killer setup. very simple and to the point. Nothing is overdone.
get that bitch on some slicks and take her out and have some fun. 8k launch ftw.
a place in west chester PA called Millers machine shop. Jeff actually commented on how he believes the head is what really did it for this build.
LOL i actually only dynoed it open. The reason being that damm camp1320 header sits lower than the stock header. I had a section welded to it with a flexpipe thinking that the flexpipe would give me some play and I could get it to line up properly but it sits too low. So I have to get someone to weld up a section that bends up slightly. However that would probably change my tune alittle.
Modified by lude98SH at 10:01 PM 2/29/2008
BABY NSX
43
Jun 14, 2007 10:14 AM
AzG35
20
Jul 3, 2004 07:14 PM
