Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
LSD manufacturers
Old Feb 29, 2008 | 10:06 AM
^AnDre^'s Avatar
Default LSD manufacturers
Are there any other LSD manufactures who produce 1 -way units other than OEM or Quaife?
Would it be possible to convert clutch systems like ATS 1.5Way or Kaaz 1.5 to 1 way?
Old Feb 29, 2008 | 02:23 PM
Crx Jimmy's Avatar
Default Re: LSD manufacturers (^AnDre^)
Cusco makes a 1 way LSD, actually theirs is user adjustable, you can take it apart and change it from 1 way to 1.5
Old Feb 22, 2009 | 07:20 AM
Js-Integra's Avatar
ATS just released a 1 way cam ring. It comes with three cam angles - 45, 55 and 70 degrees. You can convert the existing 1.5 way LSD to 1.0 way with this cam ring kit or can purchase a complete 1 way standard or Super Silent LSD.
Old Feb 22, 2009 | 10:36 AM
.:Made in OC:.'s Avatar
Stay tuned for GEAR-X clutch type LSD's soon! Contact Jeff@Special Projects MS for more info.
-Charles
Old Feb 22, 2009 | 02:21 PM
Aquafina's Avatar
MFactory. See my reviews in the trans forum.
Old Feb 22, 2009 | 02:31 PM
Battle2.0Eg's Avatar
I was just was just at Special projects today and Jeff was showing me the samples of clutch type Lsd's that are soon to be released
Old Feb 22, 2009 | 07:23 PM
Js-Integra's Avatar
It is my understanding that a gear type or helical type LSD (like the one used for Integra type R) behaves like a 2 way clutch type LSD even though it is much milder.
Old Feb 22, 2009 | 09:36 PM
Aquafina's Avatar
No. Helical only works under acceleration. Friction from constantly meshed gears (as all Honda trannys are) isn't enough to make it work under decel.
Old Feb 23, 2009 | 05:25 PM
string's Avatar
Are you saying that a helical will behave like a stock open diff under deceleration?
Old Feb 23, 2009 | 05:27 PM
gshatch's Avatar
i need to read more about LSD
Old Feb 24, 2009 | 02:57 PM
FerreiraCompetitions's Avatar
Yes, and if one wheel is off the ground or with limited traction as in snow it will be just like an open diff. Helicals are not the best type of LSD's for racing, thats why Gear-X is coming out with a clutch type soon.
Old Feb 24, 2009 | 04:58 PM
Aquafina's Avatar
Partly correct. If one wheel doesn't have traction (snow, ice, etc) power is transferred to the other wheel (whereas an open diff sends power to the wheel without traction).
dblair
May 3, 2013 01:21 PM
torir278
Transmission & Drivetrain
Jun 26, 2011 10:32 PM
AlienKrOZ
Jul 14, 2004 10:50 AM
wesuri
Sep 15, 2002 11:17 PM
KekeK-18
Oct 22, 2001 01:23 AM
