Need your expertise...
Old Jul 6, 2002 | 11:30 AM
BlueR's Avatar
Default Need your expertise...
i just finished wiring up my 93 EG beater...
it has a b16a2 with a obd1 p72 ecu...everything is running fine...the only code its throwing has to do with the 02 sensor...the p72 has four pins and my o2 sensor only has one pin...so now the check engine light is on...will the car be ok or will it run in "safe" mode?
thanx
[Modified by BlueR, 7:35 PM 7/7/2002]
Old Jul 6, 2002 | 11:34 AM
Reid's Avatar
Global Moderator
Default Re: Need your expertise... (BlueR)
It'll be fine.
My beater is throwing the same code since I'm still using my 2 wire Cx o2.
Old Jul 6, 2002 | 11:36 AM
BlueR's Avatar
Default Re: Need your expertise... (Reid)
thanx reid...
woohoo...finally got the biatch running with vtec!!!!!!
Old Jul 6, 2002 | 12:06 PM
Reid's Avatar
Global Moderator
Are you running a cable tranny?
Reid - who wants to test his new sig....
Old Jul 7, 2002 | 03:36 PM
BlueR's Avatar
sorry for the confusion reid...it a b16a2...i'm running an LS hydo tranny...
Old Jul 7, 2002 | 03:39 PM
Reid's Avatar
Global Moderator
Must be nice to fall out of VTEC when you shift.
I hope you're going to boost it.
Old Jul 7, 2002 | 04:00 PM
BlueR's Avatar
its my beater...i got the ls tranny specifically for the longer gearing so that i wouldn't be in vtec when i'm on the hwy bc the gsr ecu kicks the vtec in at 4400 rpm...no boost....no filter on a stick...i even slapped on my stock ITR exhaust on it...nobody would know just from looking at it that its hooked up...total sleeper
[Modified by BlueR, 8:01 PM 7/7/2002]
Old Jul 7, 2002 | 04:09 PM
Reid's Avatar
Global Moderator
total sleeper
I thought sleeper implied that your car was semi-fast.
B16 + LS trans =
"Come on man, floor it."
"I am."
"Oh."
Old Jul 7, 2002 | 04:13 PM
BlueR's Avatar
considering it had 70hp b4 the swap...i cannot complain
all-mtr-teg
Oct 1, 2007 07:48 PM
98IntegraLSNonVtec
Jul 31, 2006 11:49 AM
iheartmyej8
May 31, 2006 05:13 AM
ThefirstPACT
Apr 24, 2004 10:45 AM
Carp
Oct 10, 2002 08:14 AM
