Check Out Custom PCV System I Made Yesterday-Anything Wrong?
Old Feb 29, 2008 | 05:58 AM
lmike6453's Avatar
Default Check Out Custom PCV System I Made Yesterday-Anything Wrong?
Ok, i currently have a chrome valve cover(non v-tec; rs) and the problem is it does not have the hole in it for the pcv valve(middle red below). So the setup i had was just breathers on intake mani, intake, and nipple on the valve cover(right red below).
After extensive reading i figured it was best to hook it back up because oil was coming out of the valve cover. I had to do it custom, so tell me if anything is wrong with what I did...
Old Feb 29, 2008 | 07:10 AM
lmike6453's Avatar
now im thinking should i of even hooked it to the intake??
Old Feb 29, 2008 | 08:23 PM
lmike6453's Avatar
bump
Old Mar 2, 2008 | 11:59 AM
lmike6453's Avatar
bump
Old Mar 2, 2008 | 02:32 PM
Blahblah718293's Avatar
Default Re: (lmike6453)
its not perfect, you may have a vacuum leak, since the air can just bypass the throttle body, generally its suppost to be a 1 way system, intake to vc, vc to mani, but this is asking 1 tube to go both ways.
dont quote me on any of this though, run it, and if it works then no harm no foul, i think the worst thatll happen is you may have a small vacuum leak, or you may get a little oil in your intake.
Old Mar 2, 2008 | 03:43 PM
lmike6453's Avatar
is oil going through the throttle body bad? thanks for input
Old Mar 2, 2008 | 04:56 PM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">is oil going through the throttle body bad? thanks for input</TD></TR></TABLE>
It won't be good after it lumps up over time
Old Mar 3, 2008 | 06:57 AM
lmike6453's Avatar
so any suggestions about modding this?
Old Mar 4, 2008 | 05:22 AM
lmike6453's Avatar
bump
Old Mar 4, 2008 | 07:24 AM
DAtegLs's Avatar
Default Re: Check Out Custom PCV System I Made Yesterday-Anything Wrong? (lmike6453)
i think your missing an intake runner on your intake there. i just put a breather on the valve cover and one on the intake...
Old Mar 4, 2008 | 07:36 AM
lmike6453's Avatar
haha...i was thinking some more and was wondering will oil even go through the intake because the line that goes from pcv valve to intake manifold is a vacuum line
Old Mar 5, 2008 | 05:00 PM
lmike6453's Avatar
bump
Old Mar 7, 2008 | 04:13 PM
lmike6453's Avatar
ok i disconnected the one line to the intake...is that ok? just going from the valve cover to intake manifold..
ivan93egreppin210
Feb 11, 2008 10:20 AM
Shaguar47
Aug 31, 2007 03:30 PM
dpkelly
Aug 15, 2005 08:52 PM
eluder33
Mar 24, 2005 11:19 AM
R6E6I6D
May 18, 2004 07:15 AM
