92 h22 lude wont start
Old Feb 28, 2008 | 10:05 PM
twiztid440's Avatar
Default 92 h22 lude wont start
i was drivung down the road fine then all a sudden my car starts to bog down an throw black smoke out the tail pipe an backfire then it will drive fine for a sec. then do the do same it kept on doing that so i getting off the highway an the exit was going up hill ii wasnt going to make so i drop to 2nd rev it up then drop the cluth to see it that will help me make it up the hill but but it just back firerd an stalled. finaly got it home check the plugs they had a lot of carbon on them so i got new ones,with new wires and a msd coil. then before i tryed to start it back up i put some vale cleanerstuff in it.sarted it up ran a lil beter for a sec. then staled now it wont start at all... the timing is on im geting spark an fuel just to let you know please help me if you can.
Old Feb 29, 2008 | 03:59 AM
mattsnooz's Avatar
Default Re: 92 h22 lude wont start (twiztid440)
Try a compression test maybe?
I found one compression tester for 10 dollers (Its made by Powerfist, and its quite the excellent tool for 10$)
Its almost a necessity to have one, as they have a veriety of uses. One thing I learned recently in understanding the compression is that the Chilton Manual I have (Haynes knock off subsidary) sucks *** and dipicts the compression test in point form and is very unexpanded with no pictures. Either way though just make sure your partner is pushing in the gas while cranking the car around 3 cranks and that should set your compression dial (that your holding)to what your cylinder is compressing @.
If you say you have, gas and spark, than compression or perhaps something more serious like timing belt could be the issue.
Old Feb 29, 2008 | 10:31 AM
Acidcrakker's Avatar
Default Re: 92 h22 lude wont start (mattsnooz)
Timing wouldnt be right if the timing belt was effed up. Time for trouble shooting 101.
Check TPS. adn compression and get back to us
Old Mar 3, 2008 | 06:45 PM
twiztid440's Avatar
Default Re: 92 h22 lude wont start (Acidcrakker)
chek compression that good car. the car started today so went for a drive ran good for bout an hhour then rpm nedle started bouncing like at 3 or 4 grand and my car backfiring an runing like junk
Old Mar 3, 2008 | 06:51 PM
waynecoSI's Avatar
are you throwing any codes?
Old Mar 3, 2008 | 06:59 PM
vlang29's Avatar
check engine light on?
Old Mar 3, 2008 | 08:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid440 &raquo;</TD></TR><TR><TD CLASS="quote">chek compression that good car. the car started today so went for a drive ran good for bout an hhour then rpm nedle started bouncing like at 3 or 4 grand and my car backfiring an runing like junk </TD></TR></TABLE>
Whats your fuel presure?
Sounds like the fuel pump is about to quit on you
Old Mar 3, 2008 | 10:01 PM
kulrevon's Avatar
If your tach was jumping not to the motors rpm. It is most likely your ignitor.
Old Mar 6, 2008 | 11:47 AM
twiztid440's Avatar
Default Re: 92 h22 lude wont start (kulrevon)
had the igniter cheak out an it was good. my car stared the other day day an it ran good for the day but next day i started it up an it ran good for bout an hour then it wouldnt start . an it not throwing any code.any ideas
k3nnex
Dec 16, 2010 04:04 PM
twiztid440
Feb 26, 2008 04:47 AM
huepowered
Feb 20, 2007 12:13 PM
wheelmaneg6
Oct 24, 2006 08:05 AM
gnu1.6Si
Jun 14, 2004 05:09 PM
