need help ls rods on type r pistons in gsr block??
Old Feb 28, 2008 | 07:46 PM
exotik4doorcivic's Avatar
Default need help ls rods on type r pistons in gsr block??
i ordered pistons on ebay and the person said they were 2000 integra pistons
well i get them tonight and they have pr4 rods (ls??) are they shorter than gsr rods??
these are supposed to go in a gsr block with blox stage 2 cams and supertech dual valve springs and retainers
my friend works at a machine shop but i dont know how to unpress the wrist pins to put on gsr rods
this is my first ever engine build HELP
Old Aug 29, 2008 | 03:46 PM
badassmthr4000's Avatar
Default Re: need help ls rods on type r pistons in gsr block?? (exotik4doorcivic)
pr4's are 2mm longer than gsr rods. The machine shop should be able to press the pin out. If not, I would seriously suggest a different machine shop. If you want help building/rebuilding and engine, this post does a pretty throrough job of guiding you through the whole process.. https://honda-tech.com/zerothread?id=1676914] Though not exactly the same, it's close enough. Good luck
Old Aug 29, 2008 | 08:58 PM
projectTeG's Avatar
Default Re: need help ls rods on type r pistons in gsr block?? (badassmthr4000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badassmthr4000 &raquo;</TD></TR><TR><TD CLASS="quote">pr4's are 2mm longer than gsr rods. The machine shop should be able to press the pin out. If not, I would seriously suggest a different machine shop. If you want help building/rebuilding and engine, this post does a pretty throrough job of guiding you through the whole process.. https://honda-tech.com/zerothread?id=1676914] Though not exactly the same, it's close enough. Good luck </TD></TR></TABLE>
ls rod is 137mm, gsr/ITR rod is 137.9mm
why would a engine with a larger stroke have a longer rod?
Old Aug 30, 2008 | 09:40 AM
N20civicB18's Avatar
You need to use GSR rods with GSR crank
OR
LS rods with LS crank
You can install them into whatever B18 block you want
slvrslepr
Apr 21, 2013 06:58 PM
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
delsol456
Mar 5, 2008 05:50 PM
exotik4doorcivic
Mar 3, 2008 03:13 PM
Quicky
Nov 25, 2002 05:12 PM
