New product Honda Intake flange
Old Feb 28, 2008 | 05:30 PM
HR-1320's Avatar
Default New product Honda Intake flange
This is a intake flange for B18C cylinder head. It was made for me buy
JM Fabrications. This particular flange is custom and has no injector bungs. They have already finished others with bungs so you can build manifolds like stock. If you have any questions you can hit up 91TSIGuy on here. I'm sure he will post shortly to explain there product better. Please don't ask how much contact http://www.jmfabrications.com
Modified by HR-1320 at 4:30 PM 2/29/2008
Old Feb 28, 2008 | 06:18 PM
wade's Avatar
Default Re: New product Honda Intake flange (HR-1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HR-1320 &raquo;</TD></TR><TR><TD CLASS="quote">
JM Fabricatiations.
Looks great! How do you pronounce the above mentioned word?
Old Feb 28, 2008 | 09:06 PM
.dave's Avatar
i HAS questions ?
Default Re: New product Honda Intake flange (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">
Looks great! How do you pronounce the above mentioned word? </TD></TR></TABLE>
lol
Maybe this will stop the weekly posts in here looking for them.
Old Feb 29, 2008 | 05:14 AM
tony1's Avatar
Default Re: New product Honda Intake flange (.dave)
Does it follow the angle of the port, or do the runners come in at 90 deg. to the flange?
Old Feb 29, 2008 | 07:00 AM
KENetics1's Avatar
lmao. Fab-ri-ca-tia-tions
Old Feb 29, 2008 | 11:31 AM
.RTErnie's Avatar
Default Re: New product Honda Intake flange (tony1)
looks like they come in perpendicular to the head flange Tony.
Old Feb 29, 2008 | 12:29 PM
HR-1320's Avatar
Default Re: New product Honda Intake flange (.RTErnie)
Well at least I got the link right
Old Feb 29, 2008 | 12:37 PM
HR-1320's Avatar
It comes in at 90deg. Just like GE or others. But thats a good suggestion I'll pass that along.
Old Feb 29, 2008 | 02:01 PM
PSI2HI's Avatar
Former Vendor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Does it follow the angle of the port, or do the runners come in at 90 deg. to the flange?</TD></TR></TABLE>
If you had the ports coming in @ the angle you'd more then likely have problems w/ trying to keep the weld to the runners out of the boss for the injectors. I know we looked into this when we made our intake flanges and there's little space as is for weld clearance.
Old Feb 29, 2008 | 04:11 PM
weiRtech's Avatar
OG Fabricator
Default Re: New product Honda Intake flange (PSI2HI)
if designed and welded properly, it shouldn't be an issue. it is just more work for programming and machining.
Old Feb 29, 2008 | 06:45 PM
PSI2HI's Avatar
Former Vendor
Default Re: New product Honda Intake flange (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">if designed and welded properly, it shouldn't be an issue. it is just more work for programming and machining.</TD></TR></TABLE>
Basically to do this you'd have to increase the injector angle to not interfere w/ the bosses as is.
Welding properly, i'd like to hear the explanation of this one......
Old Mar 1, 2008 | 10:20 AM
Ef Si's Avatar
I have a flange here that brings the runners in on the same angle as the port.
Old Mar 2, 2008 | 03:01 PM
DaveF's Avatar
Default Re: New product Honda Intake flange (Ef Si)
lets see it !
Old Mar 3, 2008 | 05:17 AM
miller's Avatar
Default Re: New product Honda Intake flange (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">lets see it !</TD></TR></TABLE>
lol. You will see it if you see my car.
But yes the flanges are available and are correct
Old Mar 3, 2008 | 05:53 AM
tony1's Avatar
If the weld to injector bung clearance is an issue with the port angle correct, could it be made with the port extending another half inch or so out from the head so the weld is not near the injector bung?
Old Mar 3, 2008 | 07:05 AM
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">If the weld to injector bung clearance is an issue with the port angle correct, could it be made with the port extending another half inch or so out from the head so the weld is not near the injector bung?</TD></TR></TABLE>
exactly
Old Mar 3, 2008 | 07:11 AM
PSI2HI's Avatar
Former Vendor
Anythings possible if you got clientel that are willing to pay. 1/2" thicker material is some $$ as you'd be up to 1.5" but im sure its doable. Are you trying to get the runners coming in @ that angle or would having the port taper to that angle work?
Old Mar 3, 2008 | 08:23 AM
H24A96EK's Avatar
Rosco on here also can do the same thing. I have him currently making me one for an h22 i'm building with injector bungs, the 10deg angle, recessed to accept 2.25" pipe o.d, 2.0" i.d. and a billet fuel rail that mounts to the flange so there's no mock up or hassle with welding to the runners. i'll post up some pics later of the design if you guys like. i was gonna ask jmf to make me one like this but rosko got to me first. don't know how much jmf would charge for what i got goin.
Old Mar 3, 2008 | 11:53 AM
Fabman's Avatar
Lierley Fab
what if theres not a injector bung going there....
jmeyer99
Jun 29, 2012 10:24 AM
HR-1320
Welding / Fabrication
Oct 30, 2007 07:39 PM
TurbochargedInnovation
Jul 23, 2007 07:12 PM
.nate
Aug 25, 2005 08:49 AM
