gauge cluster swap help!!
Old Feb 28, 2008 | 04:10 PM
purple95's Avatar
Default gauge cluster swap help!!
I am swaping my 91 civic cluster with a 93 da cluster because it has a tach. I cannot plug the vss back into the cluster. It doesn't go in all the way, the speedometer goes all over the place, and I am getting code 17.
Why is it so hard to plug in, and why does it not click in all the way?
Old Feb 28, 2008 | 04:48 PM
Crx Jimmy's Avatar
Default Re: gauge cluster swap help!! (purple95)
it should work fine, they both have the same ends on the cables
Old Feb 28, 2008 | 06:01 PM
purple95's Avatar
Default Re: gauge cluster swap help!! (Crx Jimmy)
That's what I thought too, but I wasn't clicking in place. I tried pushing it in as hard as I could and ended up cracking the dam thing . Does any body have a da, ls cluster for sale.
Old Feb 28, 2008 | 06:19 PM
grog's Avatar
along with pushing it try twisting it, mine always needs to be twisted a bit to snap in.
Old Feb 28, 2008 | 06:47 PM
purple95's Avatar
Default Re: gauge cluster swap help!! (grog)
I tried, but to late the cluster cracked. Thanks anyways, Ill try that on the next cluster.
Old Feb 28, 2008 | 06:48 PM
purple95's Avatar
Can I drive my car with the vss cable disconnected?
Old Feb 29, 2008 | 09:24 AM
90_hatch_b16's Avatar
yes but if you have vtec it will not engage... oh and you wont be able to tell how fast you are going
Old Feb 29, 2008 | 12:47 PM
phaphon's Avatar
hey if your still looking for a cluster i got a 91 rs that i just crash its going to pick and pull in stockton soon so let me know if you need it
Old Feb 29, 2008 | 04:28 PM
SETI20's Avatar
I have several CRX vtec clusters for sale.
Follow link in my sig.
Old Feb 29, 2008 | 07:31 PM
bayron's Avatar
yeah i was trying 2 make the same but i could it.. i found all the wires but didnt fit.. so i have a cluster for da for sale!!!
Old Mar 1, 2008 | 08:47 AM
purple95's Avatar
Default Re: (bayron)
Yea, its a tight fit. You have to shave some off the side of the cluster and remove the old mounting brackets to get it wedged in.
Were you able to connect the vss cable?
I found a 90-91 crx cluster with a tach.
Could any body help me find a how to on this install?
Also, I noticed the vss cable at the tranny came out a bit. Is it soppoused to be loose like that. I pushed it back in but still would come up if I pulled on it. Did I break it?
twedter02
Sep 24, 2010 10:00 PM
DaFredsta
Oct 18, 2009 01:31 AM
chinkyEyez
11
May 21, 2004 01:51 PM
