wtf........valve cover still leaking
Old Feb 28, 2008 | 11:24 AM
slowB20ej8's Avatar
Default wtf........valve cover still leaking
whats up i just replaced the vc gasket on my jdm b20 first i just went to autozone and got a felpro gasket it didnt even fit, so i went straught to honda and got the right one, so i get it home put it on even put a little bit of that black gasket stuff around it and its still leaking ......any ideas why
Old Feb 28, 2008 | 11:46 AM
B16B_coupe's Avatar
HRD PKR
Default Re: wtf........valve cover still leaking (96lsivtech)
Are you using the right amount of torque?
Make sure one do it sorta like lug nuts when tighting.. top left bottom right etc....
Also make sure to clean the surface on the head before installing
Old Feb 28, 2008 | 11:49 AM
saywhat's Avatar
pcv valve working?
Old Feb 28, 2008 | 11:52 AM
-Gambit-'s Avatar
Default Re: wtf........valve cover still leaking (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Are you using the right amount of torque?
Also make sure to clean the surface on the head before installing</TD></TR></TABLE>
x2
it might be leaking out of your cam seal, really really common problem with b series.
Old Feb 28, 2008 | 11:59 AM
slowB20ej8's Avatar
Default Re: wtf........valve cover still leaking (-Gambit-)
tighten them down front left back right back left front right the the center.......its only leaking on the front and rear
Old Feb 28, 2008 | 12:02 PM
-Gambit-'s Avatar
warped vc or head ?
Old Feb 28, 2008 | 12:49 PM
blk92_d16's Avatar
I believe the proper sequence is like head studs...inside to outside.
Old Feb 28, 2008 | 01:08 PM
REAL TIME's Avatar
Default Re: (blk92_d16)
gasket on backwards? i know on my b16 there is only one way to put the gasket
Old Feb 28, 2008 | 01:12 PM
1992Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">I believe the proper sequence is like head studs...inside to outside. </TD></TR></TABLE>
Also only put sealer on the sharp corners, not on the hole rubber gasket.
Don't over tighten the bolts. The gasket seals not the tightness of the old bolts. The bolts will snap easily.
They shouldn't leak you must have something wrong.
Old Feb 28, 2008 | 02:46 PM
Frickr's Avatar
Default Re: (1992Si)
if you overtighten the valve cover, your gasket will just mush out and wont seal. also its possible to bend the valve cover. do you have access to a straightedge? i would check to see if its warped myself, then go from there
CRseXy
May 8, 2005 09:15 PM
gsacuraintegra99
Mar 17, 2005 11:21 PM
UNDER PRESSURE
May 14, 2004 10:24 AM
JBBNJ609
Sep 21, 2003 09:16 PM
bey
May 30, 2003 10:43 PM
