blox vs itr sway bar?!?
Old Feb 28, 2008 | 10:07 AM
ls_bitik's Avatar
Default blox vs itr sway bar?!?
i was wondering.. which one is better? i know itr is 23 and blox is 21 mm.. which one would you guys pic?
Old Feb 28, 2008 | 10:12 AM
mrdeadman's Avatar
They let me pick
Default Re: blox vs itr sway bar?!? (ls_bitik)
Jdm ITR is 23mm. The USDM is 22mm. I'd get the ITR personally, if you get the 23 I'd invest in the asr bracket, but if you just get the USDM, the beaks or bsq kit will suffice. USDM is $80 and the beaks kit is $75. Bsq kit is $20.
Old Feb 28, 2008 | 10:15 AM
VTEC_PRODUCTION's Avatar
Default Re: blox vs itr sway bar?!? (mrdeadman)
you can get the asr bar and brace for a decent price off ebay all in one kit. and its 22mm. id opt for that option.
Old Feb 28, 2008 | 10:18 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">Jdm ITR is 23mm. The USDM is 22mm. I'd get the ITR personally, if you get the 23 I'd invest in the asr bracket, but if you just get the USDM, the beaks or bsq kit will suffice. USDM is $80 and the beaks kit is $75. Bsq kit is $20. </TD></TR></TABLE>
lol dude have you seen the difference between the ASR brace and the beaks kit?
You can use a beaks kit with a 22mm bar or a 23mm bar if you never plan on driving the car hard. The beaks kit should really only be used up to like 19mm or so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">you can get the asr bar and brace for a decent price off ebay all in one kit. and its 22mm. id opt for that option.</TD></TR></TABLE>
Yep. JHPUSA has a great price on those peices right now.
Old Feb 28, 2008 | 10:21 AM
Default Re: blox vs itr sway bar?!? (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
Yep. JHPUSA has a great price on those peices right now.</TD></TR></TABLE>
and just for future info it seems like jhpusa on ebay is really the only reputable company on ebay...
Old Feb 28, 2008 | 01:30 PM
ls_bitik's Avatar
Default Re: blox vs itr sway bar?!? (VTEC_PRODUCTION)
for the jdm ones.. do i need to change my control arm? i currently have the blox LCA and comptech tie bar.. does it just bolt on? dont really have a clue. thanks!
Old Feb 28, 2008 | 01:53 PM
i know that sways made for non type r models will not fit type r integras...im not sure the other way around...
Old Feb 28, 2008 | 04:46 PM
ls_bitik's Avatar
will the itr sways fit ls? bolt on? itr and ls have different controlarms..
Old Feb 28, 2008 | 06:33 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_bitik &raquo;</TD></TR><TR><TD CLASS="quote">will the itr sways fit ls? bolt on? itr and ls have different controlarms..</TD></TR></TABLE>
It will bolt on, but you need a subframe reinforcement kit.
Old Feb 28, 2008 | 06:50 PM
looie's Avatar
heres a pick of a itr sway bar with a ASR brace and omni control arms on my ride. the endlinks didn't match up perfectly but a little bit'o bending did the key. or the correct way to go would be after market end links. also, the lca's dont have threads so you have to go and buy your own bolds and "nuts" to put them on. if you do that i highly recommend you buy nice bolts and learn how bolts, washers, lock washers, and nylon nuts work and fit. because you do not want one of those things snapping or comming off when your doing 100 around a corner.
Old Feb 28, 2008 | 06:59 PM
what gsr's Avatar
Default Re: blox vs itr sway bar?!? (spyshot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyshot &raquo;</TD></TR><TR><TD CLASS="quote">heres a pick of a itr sway bar with a ASR brace and omni control arms on my ride. the endlinks didn't match up perfectly but a little bit'o bending did the key. or the correct way to go would be after market end links. also, the lca's dont have threads so you have to go and buy your own bolds and "nuts" to put them on. if you do that i highly recommend you buy nice bolts and learn how bolts, washers, lock washers, and nylon nuts work and fit. because you do not want one of those things snapping or comming off when your doing 100 around a corner.
good info!
Old Feb 28, 2008 | 07:31 PM
ls_bitik's Avatar
Default Re: blox vs itr sway bar?!? (what gsr)
that helps alot.. thanks!
Old Feb 28, 2008 | 07:38 PM
mrdeadman's Avatar
They let me pick
.</TD></TR></TABLE>
Yes, yes I have. Many people on this site have been using the beaks or bsq kit for a long time with zero issues. Integras have stronger subframes than civics, you'd need an asr for a civic. I have run the beaks kit and ITR 22mm on my integra hard for 2 years with no issues.
Old Feb 28, 2008 | 09:13 PM
SuckMyDOHC's Avatar
96-97 JDM ITR and 97-01 USDM ITR all used the 22mm rear sway bar. the 98-00 JDM ITR used the 23mm. Even if you track your car, the beaks or bsq kit will work fine. I've been using the BSQ kit with my 22mm ITR sway bar on my LS for years with plenty of track events and hard turns without a problem. the 92-95 Civic subframes are just as strong as integra subframes, its the 96-00 you have to worry about. Stiff spring rates will also help out a lot
Old Feb 28, 2008 | 10:10 PM
racebum's Avatar
Default Re: (SuckMyDOHC)
suspension techniques also has a 19mm bar with relocated attachment points that should make it feel stiffer than a standard 19mm. basically they move the end links out to the shock bolts which reduces the leverage on the arm, you also get their version of a beaks kit all in one box for $129. it's a simple all in one package that really flattens out a basic 350-500 dollar shock and spring kit.
Turboteggy
Suspension & Brakes
Jul 10, 2006 10:11 PM
intougera
Dec 20, 2004 04:54 AM
Wazup
Aug 16, 2002 05:21 PM
GS-R_nut
Jul 17, 2002 01:35 PM
