Maintenance: Take a look and see if i got everthing
Old Feb 28, 2008 | 07:10 AM
Convert's Avatar
Default Maintenance: Take a look and see if i got everthing
Trying to make a list of things i need to do, and just looking for a little input
edit: the chasis is at 135k, motor is JDM so...60k? Im going to seafoam to keep her clean, but past that, i have no idea what the car has done or not, about to put mobile one in and see what happens.
New thermostat/ flush and fill on coolant
tranny fluid change
oil change (duh)
brakes f/r rotors and pads
p.s. since winter has been on, my car has had a terrible time warming up. im assuming that the t-stat is stuck open which would be the big reason why it wont warm up even after a 20 min drive. any input is greatly appreciated!
THANKS ALL!!!
Modified by Convert at 11:22 AM 2/28/2008
Old Feb 28, 2008 | 07:16 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: Maintenance: Take a look and see if i got everthing (Convert)
Oil filter
When were plugs changed? Cap, rotor?
When was the last time brake fluid was changed? New fluid make a big difference in brake feel and operation.
Old Feb 28, 2008 | 07:31 AM
OMGWTFBBQ!'s Avatar
Fuel filter, maybe check your ground wires, air filter maybe? Remember to buy new crush washers for your drain plugs.
Old Feb 28, 2008 | 08:01 AM
4do4damsho's Avatar
Default Re: (OMGWTFBBQ!)
yea timing belt maybe. and thermostat
Old Feb 28, 2008 | 08:02 AM
hrs-parker's Avatar
basic tune up..well atleast mine..
oil
oil filter
air filter
fuel filter
pcv valve
tranny flush
coolant flush
spark plugs
spark plug wires
Old Feb 28, 2008 | 08:09 AM
.boost3d.'s Avatar
inspect brake lines make sure no leaks? like another guy said water pump and timing belt?
Old Feb 28, 2008 | 08:12 AM
Convert's Avatar
Default Re: (4do4damsho)
oil filter=check
plugs=recently changed
cap/rotor=no clue
brake fluid=needed
fuel filter=needed
grounds=needed
thermo=see below
pcv valve=needed im sure
tranny flush=needed
coolant flush=bad needed
spark plug wires=new
yeahm the thermo si still puzzling me. anyone else on this? like i said, the main problem is the fact that the car isnt warm even after a 20 min drive.
thanks!!!
Old Feb 28, 2008 | 08:14 AM
4do4damsho's Avatar
Default Re: (Convert)
just stick a new thermostat housing in. good to go!
Old Feb 28, 2008 | 08:21 AM
mortificationrock's Avatar
You also might want to consider buying a new temp sensor, just to make sure the old one isn't throwing you off.
Old Feb 28, 2008 | 11:29 AM
Convert's Avatar
Default Re: (mortificationrock)
well, after taling with my mech, he surmised that maybe some jackass had removed the water pump altogether. at any rate.
thanks again all!
Old Feb 28, 2008 | 11:32 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Convert &raquo;</TD></TR><TR><TD CLASS="quote">well, after taling with my mech, he surmised that maybe some jackass had removed the water pump altogether. at any rate.
thanks again all!</TD></TR></TABLE>
No, (s)he is wrong. The water pump is driven by the timing belt.
Old Feb 28, 2008 | 11:40 AM
Convert's Avatar
Default Re: (mcvtec)
actually ima douche. i meant thermostat.
way to look like a jackass. thats what i get for working and looking at H-T
Old Feb 28, 2008 | 11:49 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Convert &raquo;</TD></TR><TR><TD CLASS="quote">actually ima douche. i meant thermostat.
way to look like a jackass. thats what i get for working and <FONT COLOR="red">looking at H-T</FONT>
No big deal. What did you mean by that (in red)?
Old Feb 28, 2008 | 12:17 PM
Convert's Avatar
meaning trying to concetrate on 2 things at once. im a photographer and i had a million people trying to talk to me while posting that, so i got a wee bit confused
nukem384
Mar 16, 2010 07:20 AM
sony224422
Feb 20, 2006 03:54 PM
trustbuddy
Feb 26, 2003 12:17 PM
Flux
Jun 17, 2002 02:28 PM
InfamousRS
Oct 5, 2001 09:55 PM
