FS: 12" Treo engineering SSI 12.44 subwoofer.
The sub its self works great, here are some specs from the website. Very reputable subwoofer. Price is 220 OBO Picked up price dropped 200 FIRM
# Precision CNC-machined low-carbon steel motor structure with durable and attractive polished nickel finish (288oz on SSi10.xx-SSi15.xx, 488oz on SSi18.xx)
# High-flow large diameter hyper-extended vented pole piece keeps it cool
# Black color-matched strontium ferrite magnet
# High excursion motor structure and suspension design
# Five-layer Poly-ether UV-treated foam surround
# large-diameter high-temperature Nomex dampers
# Integrated tinsel leads for increased reliability and enhanced sound quality at high excursion
# Attractive anti-resonance Die-cast aluminum basket with TREO Engineering-exclusive perimeter venting
# Mica-impregnated polypropylene cone and dustcap
# 3.0 inch, high-temperature aluminum voice coils with integral heatsink
# 750 Watts RMS power handling on SSi10.xx, SSi12.xx & SSi15.xx
# 1000 Watts RMS power handling on SSi18.xx
# Dual 2 Ohm and dual 4 Ohm voice coils available for maximum installation flexibility
# Nickel-plated spring-loaded push terminals retain up to 8 AWG wire
http://treoonline.com/ssi.html
Modified by looney at 9:28 AM 2/29/2008
