Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
10k mile inspection
Old Feb 27, 2008 | 10:31 PM
teggy2154's Avatar
Default 10k mile inspection
What is recommended to be done at 10k miles. I have had one oil change. Btw its a 3 yr lease n have had it since july 07' and that makes any difference. I need to get an oil change. Do I rotate tires? Anything else?
Old Feb 28, 2008 | 06:36 AM
FBPSidan's Avatar
Default Re: 10k mile inspection (teggy2154)
Do whatever your maintence minder says if you wanna go by the book... at 10k here in vegas we do usually just oil/filter changes and rotates (if needed)
Old Feb 28, 2008 | 12:08 PM
yuning83's Avatar
Default Re: 10k mile inspection (FBPSidan)
the stuff at 10k is tire rotation mainly possibly an alignment after that. But the dealer will tell you they will inspect bouch of stuff such as brake and all fluid levels etc. Oil change is kind of on it's own, you'll change it everytime it gets low on the %.
If you gonna buy the car, then do whatever you feel it's good for the car, but if you are not buying it at the end, then do only what's required I guess.
Old Feb 28, 2008 | 02:52 PM
high_revs's Avatar
10K:
-front brake service (clean and lube caliper sliders)
-rear brake service
-lube oil filter
-lube door hinges, hood hinges, latch, battery terminals
-rotate tires
-top off all fluids
thats pretty much it...
alignment is reccomended every 15k
chiquito
64
Mar 21, 2008 11:07 AM
socallmechris
15
Jan 20, 2008 09:44 AM
AutoXer
13
Sep 8, 2005 12:11 PM
JDMflavor_EJ
16
May 18, 2004 03:32 PM
2qwik2nv
Acura TL, RL & ZDX
Jan 12, 2003 02:25 AM
