ecu problem
Old Feb 27, 2008 | 08:52 PM
egbaby's Avatar
Default ecu problem
so i checked the codes on my chipped p28 ecu and it was throwing code 20. The thing was that my friend put his chipped ecu in my car and everthing was fine. I put my ecu in and everything was fine. Then when i turned it off for 10 mins the light turns on and my car runs funny. the code is the ELECTRICAL LOAD DETECTOR. Is it possible to bring the ecu to a shop and they can tell me if my ecu is the problem. Or do you think all i need to do is replace the fuse box.
Old Feb 27, 2008 | 09:01 PM
Crx Jimmy's Avatar
Default Re: ecu problem (egbaby)
Your friends chipped p28 probably has the load detector disabled, mine is chipped like that as well. you can delete it with most tuning programs
Old Feb 27, 2008 | 09:08 PM
egbaby's Avatar
how much do you think it would cost if i brought it to the shop. Oh yeah i forgot to say that a week prior my brother dwn shifted from 3rd to second while racing. And my cars check engine light turned on and read code 20. So do you think that that part of my ecu fried??
Old Feb 27, 2008 | 09:16 PM
jax97hx's Avatar
Default Re: (egbaby)
what are you tuned with ? its a simple 5 min job to disable the eld if u want u could even mail me your chip ill disable it and send it back or pay me and ill send u a fresh chip with a base map of your choice...
or you could find someone local and ask them to do it they prolly wont charge
Old Feb 27, 2008 | 09:19 PM
egbaby's Avatar
im new to this honda thing and i dont want to sound stupid. But when i do go to the shop what do i ask them to do???
Old Feb 27, 2008 | 09:21 PM
jax97hx's Avatar
first find out what ur tuned with .. prolly crome ...then find someone who tunes crome in your area and simply ask them to disable your eld plz
that should do it
Old Mar 7, 2008 | 11:23 AM
egbaby's Avatar
so i figured out the problem. My friend said that some of the prongs on the chip got burnt. And he told me i had a h22 map on it. Right now he replaced it with a gsr chip. What do you think would be the best setup for a hatch with an h22. ohh yeah my car was running great with the chip but can he copy the settings from my old chip to my new chip even though its burnt? And can a chip really make your car run better???
Modified by egbaby at 12:40 PM 3/7/2008
Jimster480
Engine Management and Tuning
Aug 30, 2010 02:23 PM
4ghatch
May 2, 2008 11:34 PM
ICEMAN707
12
Jul 2, 2006 03:45 PM
CRXb18Turbo
Oct 20, 2005 05:48 PM
SOHC_MShue
Nov 11, 2004 11:52 AM
