need help!!! my heater is not working!
hello guys!
I really need some help. My car had a little problem few days ago, the coolant was leaking and the engine temperature went up really high because of that. I have my car towed right away, and the shop found one of the hose that was leaking and replaced it. I thought everything was good until I drove my car back home. The heater was not working, and my *** was freazing!
What could have gone wrong? any ideas? The heater was just fine before the coolant problem.
well I would bleed the coolant first cuz when the replaced the hose and even when you had the leak you probably got a lot of air in your coolant system and that could cause no heat..so do that first and check back and let us know what happens..just incase you didnt know what to do take off your radiator cap..turn your car on and turn the heat all the way up but do not turn your fan on..just the heat..and let the bubbles leak out..watch the coolant and if it starts to get low pour some more in..the easiest way to do it thought is to go to honda and buy a funnel made especially for bleeding the coolant..its very simple and is the easiest way to do it i think it is like 10 bucks
Wrona
Nov 6, 2011 02:26 PM
fast+forward
Jan 29, 2007 03:13 PM
