need quick help. how do you remove a wire from....
Old Jul 6, 2002 | 06:20 AM
Mikey3000's Avatar
Default need quick help. how do you remove a wire from....
the ECM's harness? i bent back the gray plastic piece which clips down on top of the wires, but the wire still won't come out. is there a trick to this?
Old Jul 6, 2002 | 01:50 PM
Mikey3000's Avatar
Default Re: need quick help. how do you remove a wire from.... (Boss Hogg)
someone knows this!
Old Jul 6, 2002 | 01:55 PM
R_yd's Avatar
paper clip or a big needle... those wires are held by tabs that you need to push down...
Old Jul 6, 2002 | 02:15 PM
Mikey3000's Avatar
Default Re: need quick help. how do you remove a wire from.... (Rspool)
where are the tabs?
Old Jul 6, 2002 | 02:16 PM
Kamin's Avatar
i think he means to remove it from the ecu
not the harness
just pull the wire, it should pop out with a little black grommet attached.
Old Jul 6, 2002 | 02:21 PM
Mikey3000's Avatar
Default Re: need quick help. how do you remove a wire from.... (KAMiN)
i tried doing that and i could tell that the wire was coming out w/o the steel piece coming out. i can feel it jiggle, but it won't budge past a certain point.
Old Jul 6, 2002 | 09:00 PM
salbaje's Avatar
there is an indentation in there where it is held in. best way is stick a needle in there and pull out the wire.
Old Jul 7, 2002 | 04:53 AM
Mikey3000's Avatar
Default Re: need quick help. how do you remove a wire from.... (salbaje)
ok i'll try that.
SCMFOX
Dec 21, 2017 09:16 PM
G2_Fella
Oct 11, 2008 08:21 PM
garyc17
16
Aug 28, 2006 09:30 PM
steve0unce
Nov 19, 2004 09:48 PM
prestonpark
Dec 1, 2003 10:16 AM
