overpressurized coolant system?
Old Feb 27, 2008 | 05:55 PM
nonvtec92's Avatar
Default overpressurized coolant system?
Hey everyone.
My coolant system is super pressurized, and i'm trying to figure out what's going on? Once the car is warmed up and driven, coolant sprays all over the engine bay. It's coming out from around the radiator cap. (I've tried 3 different caps)
With the stock spring style clamps it started leaking around the upper and lower radiator hoses. I put on the screw style clamps, and tightened it like crazy and that fixed that; although it was still leaking around the cap.
New upper and lower radiator hoses.
Drove the car for about 2 hours, and then a smaller coolant hose, the "heater hose" blew up and left me stranded.
What's going on?
It seems like my coolant system is WAY WAY over pressurized.
Is this characteristic of a blown headgasket? Is there anything else it could be?
Thanks all.
Old Feb 27, 2008 | 05:59 PM
1992Si's Avatar
HG is blown.
Old Feb 27, 2008 | 06:03 PM
Frickr's Avatar
Default Re: (1992Si)
friend had the same problem, ended up being a headgasket, and a cracked head. he got the bright idea to pull off the outer 2 layers on a multilayer headgasket.
Old Feb 27, 2008 | 06:07 PM
HondamanXxX's Avatar
GO GIANTS!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">HG is blown.
Old Feb 28, 2008 | 04:28 PM
nonvtec92's Avatar
Default Re: (HondamanXxX)
i was thinking that was the case...
thanks for the replies.
Old Feb 28, 2008 | 04:40 PM
instrument's Avatar
make sure you get a metal headgasket!
Old Feb 28, 2008 | 07:13 PM
Kista20's Avatar
Default Re:
yeah seriously get that thing fixed as soon as you can, it sounds like to me that the head is cracked because it's pressurizing that much into your coolant system and even if the head isn't cracked it will more than likely be warped and you can either shave it down if it isn't too bad and run a thicker head gasket to bring the compression ratio back to par or just get another head to replace it with.
Old Feb 28, 2008 | 07:20 PM
projcinco's Avatar
Default Re: overpressurized coolant system? (nonvtec92)
yeah its the head gasket thats what happened to my ride
Old Feb 28, 2008 | 09:01 PM
dr.garagetuner's Avatar
did you bleed the system when u put more coolant in? That will cause it to be really pressureized also is the upper radiator hose hard while the lower radiator hose is soft?
Old Feb 28, 2008 | 09:04 PM
-Gary-'s Avatar
Head Gasket for sure.
Old Feb 29, 2008 | 07:20 AM
nonvtec92's Avatar
Default Re: (-Gary-)
i bled it and kept adding coolant until bubbles weren't coming up anymore. probably 20-30minutes. what's the proper way to bleed a system? does the heater need to be running? etc...?
i'd say the lower hose is softer then the upper one yes. i'm not really sure though...
prodjay10
Honda Civic (2001 - 2005)
May 27, 2015 09:23 AM
KhmerPride
Apr 29, 2015 05:38 PM
raju687
Sep 16, 2011 05:42 PM
Jeffrey9
Nov 16, 2005 10:31 AM
