H23 Vtec Alternator Question
Old Feb 27, 2008 | 03:16 PM
AdReNaLiN's Avatar
Default H23 Vtec Alternator Question
Are H22 and H23 alternators the same?
Which alternator are you running on your H23vtec?
Can I swap alternators from the h22 block to the h23 bock?
and yes, i searched.
Old Feb 27, 2008 | 04:46 PM
snobordboy's Avatar
Moderator
I used the alternator from my H23 on my H22, so they should all be exactly the same.
Old Feb 27, 2008 | 07:28 PM
Acidcrakker's Avatar
Default Re: (snobordboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snobordboi &raquo;</TD></TR><TR><TD CLASS="quote">I used the alternator from my H23 on my H22, so they should all be exactly the same.</TD></TR></TABLE>
Almost, there is an extra rib on the H22 altenator
Old Feb 27, 2008 | 07:48 PM
tarheelsoldier's Avatar
Default Re: (Acidcrakker)
I am using my h23 altenator. they are the same voltages and ampreges.
prelude_93vtec's Avatar
So you can run it just with a different belt?
Old Feb 27, 2008 | 07:53 PM
Default Re: (prelude_93vtec)
If you run a h23 alt on an h22, you are going to have to use the belt off a h23.
5 ribs on h23
6 ribs on h22
I have h23 alt on an h22, I use the h23 belt
Old Feb 28, 2008 | 07:25 AM
if your that concerned change the pulleys. you can change those easily
Old Feb 28, 2008 | 04:00 PM
AdReNaLiN's Avatar
Great, so the alternators are the same, and its just the pulley that is different on each model.
Has anyone had any experience with an Ebay 160 amp alternator?
http://cgi.ebay.com/ebaymotors...65569
blowngsr1
Feb 18, 2010 09:42 PM
h23vtec_dc2
Sep 14, 2008 02:11 PM
pkolaboy
Jun 27, 2008 06:47 PM
darkspector2.0
Dec 5, 2007 09:01 PM
h23vtec_dc2
Jun 22, 2007 07:20 AM
