B18A1 swap into EG will OEM D mounts work? if not which ones?
Have a questions B18A1 90-93 LS engine putting into a 92-95 Civic, will the D series rear mount work with the B18A1? and if so do you use the B18A1 Rear Bracket or stock 92-95 D? Also will the stock driver side mount work with the B18A1? which is a stager 2 bolt pattern as the stock D mount?
correct but for the 2 mounts that I am wondering about is the rear and driver side i already have the conv. tranny mount I just need to know which OEM mount combination works i searched but couldnt find anything D/B
I guess my concern right now is can the driver side engine bracket on the A1 be switched to the B1? I am thinking not because one bracket has 3 (A1) bolts to the block the other has 2 (B1)
i believe you need tranny mount and rear backet out of a 94-01 style integra. you can only use the driver side d series mount
you must use the b18b1 mount from the engine (post mount) you must get the l-bracket in the back, and i think the d-series is the same, but i cant remember if thats the one i used or not. good luck i hope this helped
D16SiHatch
13
Mar 29, 2008 05:05 PM
97civicdx
Feb 9, 2005 12:32 PM
lowboost civ
Mar 9, 2003 07:23 PM
Will Albers
Sep 30, 2002 08:03 AM
